It is currently Wed Jul 08, 2026 21:03
 Post subject: i'm too lazy
PostPosted: Thu Nov 27, 2003 0:49
due to a tower change my lcd isn't plugged...
& i'm too lazy to put it :?
will try this week end if i find time
and maybe there will be a few things new for lcdinfo
PostPosted: Thu Nov 27, 2003 0:57
now i put my brain ON, i think about this... what do you need to make a plugin that access shared memory? all datas are strings :)
(want a wmp plugin? with horrible spectrum analyser?)
typedef struct
   char name[255];            // Name of the current
   char author[255];         // Author of the current
   char duration[12];         // Duration of the current
   char currentpos[12];      // Current Position
   int    spectrum[128];         // The spectrum values
   int  scope[128];         // The scope values
   char name_nxt[255];         // The name of the next song
   char pourcent;
} WMP_stat_struct;
and name of the shared aera, something like:
WMP-LCDStudio[/code]
PostPosted: Fri Nov 28, 2003 0:04
Same kind shared memory is used with the winamp2 plugin so it shouldn't be very difficult to make the WMP plugin. ;)
