It is currently Mon Aug 24, 2026 12:41
 Post subject: Winamp2.Running??
PostPosted: Fri Jan 09, 2004 12:20
What does the following mean in the log:
8:51:2:999  Remove flag: Winamp2.Running
8:51:4:0  Remove flag: Winamp2.Running
8:51:5:1  Remove flag: Winamp2.Running
8:51:6:2  Remove flag: Winamp2.Running
8:51:7:4  Remove flag: Winamp2.Running
8:51:8:5  Remove flag: Winamp2.Running
8:51:9:6  Remove flag: Winamp2.Running
8:51:10:7  Remove flag: Winamp2.Running
8:51:11:9  Remove flag: Winamp2.Running
8:51:12:10  Remove flag: Winamp2.Running
8:51:13:11  Remove flag: Winamp2.Running
8:51:14:13  Remove flag: Winamp2.Running
8:51:15:14  Remove flag: Winamp2.Running
8:51:16:15  Remove flag: Winamp2.Running
8:51:17:16  Remove flag: Winamp2.Running
8:51:18:18  Remove flag: Winamp2.Running
I dont have the winamp plugin running, so why?
Rudi Grobler
PostPosted: Fri Jan 09, 2004 12:44
do you have the wmp one running?
PostPosted: Fri Jan 09, 2004 12:59
No, It is not running. I just checked my task manager and I found a app running called winam... and I ended it. Ran lcdinfo again and received the same messages!!!
Rudi Grobler
PostPosted: Fri Jan 09, 2004 13:04
the plugin is not running or the windows media player ;)
because i based my wmp plugin on the winamp's one and i just saw 2days ago that there was something of winamp in the wmp plugin
PostPosted: Fri Jan 09, 2004 13:07
Sorry, No... I just restarted my machine, deleted the log file and stoped the winamp agent. It is now working fine. I don't know what happend!!! Why is it writing the message thou? I ran the program for less than a 1/2 hour and I have a 350kb log file? If I run this program for 2 or 3 days I will have a log file that is a log of megabytes!!!
Rudi Grobler
PostPosted: Fri Jan 09, 2004 13:41
strange...
only henri could tell you what mean remove flag.
my bug was with status image i think
no link with running
maybe thisis linked to an internal value, about wich plugin is curretnly running
PostPosted: Fri Jan 09, 2004 14:09
Ah, you are running build16pre :)
Last time I worked on it I made some experiments with support for "flags" that would tell if for example winamp is running. These flags could then be used to only show winamp screen when winamp is running and other things.
The messages in the log were just for testing but as I didn't finish the flag stuff yet they were not removed.
PostPosted: Fri Jan 09, 2004 14:22
OK, It was just very stange because I even after I closed winamp. I still received this message!!! If its purpuse is to tell if winamp is running and it still says runing even if the agent is shut down :? Has anybody else notice this or might something else be wrong in my setup. I just tested it again by shutting down the agent and I still have the message!!
Rudi Grobler
PostPosted: Fri Jan 09, 2004 14:28
where is the pre16 :cry:
PostPosted: Fri Jan 09, 2004 14:35
O, yes I am...
Rudi Grobler
PostPosted: Fri Jan 09, 2004 21:07
Build 16 is still considered unfinished and has things that might not make any sense like these messages.
Build 15 is the one to use for a "stable" version.
DarkElf:
Drop me a mail if you'd like to get the same build16pre as rudi but be prepared for strange things like described here. Mostly I've been just adding new unfinished features and bugs ;)
PostPosted: Fri Jan 09, 2004 21:21
No I do'nt need the pre16, i just sawn what does it do (system info plugin), and i don't need circle or degree line at the moment...
Users browsing this forum: No registered users and 55 guests
