It is currently Sat Oct 03, 2026 4:01
 Post subject: Editing the screen
PostPosted: Sat Oct 25, 2003 15:14
In the screens directory resides a file named screens.xml. You can put there the screens you want to see in LCDInfo.
Example of screens.xml:
<screens>
   <screenfile>128x64\bug.xml</screenfile>
</screens>
Explanation for the screen file itself is below:
First thing you can put in the file is the screen name:
<name>Winamp2</name>
Then you can put there some action which will change to another screen.
This will change to next screen after 5 seconds:
   <action>
      <id>Core.NextScreen</id>
      <delay>5000</delay>
   </action>
This will change to a screen named "System" after 2 seconds.
   <action>
      <id>Core.ChangeScreen</id>
      <parameter>System</parameter>
      <delay>2000</delay>
   </action>
You can also omit the delay parameter but then the action will be executed immediately.
Items that can be currently placed on the screen and their options are
text
x and y: position in character coordinates
scrolltype: none, left
textpos: left, right, center
fieldsize: size of the field reserved for the text
textdata: text itself
refresh: how often item is refreshed (ms)
plugintext
varid: identification string of the variable
x and y: position in pixel coordinates
imagebitmap: bitmap filename
pluginimage
imageid: identification string of the image
animation
framebitmap: filename of a frame bitmap
Example:
<screen>
   <action>
      <delay>5000</delay>
   </action>
   <item type="text" x="0" y="5">
      <scrolltype>none</scrolltype>
      <textpos>left</textpos>
      <fieldsize>5</fieldsize>
      <textdata>Total</textdata>
      <refresh>500</refresh>
   </item>
   <item type="plugintext" x="14" y="7">
      <varid>fraps_fps</varid>
   </item>
      <imagebitmap>images\bg_nfo_128x64.bmp</imagebitmap>
   </item>
   <item type="image" x="47" y="24">
      <imagebitmap>images\winamptext48x10.bmp</imagebitmap>
   </item>
   <item type="image" x="119" y="10">
      <imagebitmap>images\batt8x50.bmp</imagebitmap>
   </item>
   <item type="pluginimage" x="50" y="8">
      <imageid>image_test</imageid>
      <refresh>100</refresh>
   </item>
   <item type="animation" x="95" y="0">
      <framebitmap>Bug\Wait_1.bmp</framebitmap>
      <framebitmap>Bug\Wait_2.bmp</framebitmap>
      <framebitmap>Bug\Wait_3.bmp</framebitmap>
      <framebitmap>Bug\Wait_4.bmp</framebitmap>
      <framebitmap>Bug\Wait_5.bmp</framebitmap>
      <framebitmap>Bug\Wait_6.bmp</framebitmap>
      <framebitmap>Bug\Wait_7.bmp</framebitmap>
      <refresh>200</refresh>
   </item>
</screen>
PostPosted: Sat Nov 29, 2003 15:04
Description edited to reflect build 13.
PostPosted: Wed Feb 04, 2004 0:03
How I spend a lot of time to find code plugin trough the forum, I finally found that all codes are simply available in the file LOG.TXT :mrgreen:
Perhaps it coulds helps uncoders who try to configure LCDinfo like me :?
PostPosted: Sat Feb 26, 2005 9:49
is there a program where i can make my screens?
PostPosted: Mon Feb 28, 2005 1:35
There is...
Here
http://forum.lcdinfo.com/viewtopic.php?t=600
However I do actually recommend learning how to write your own screen files. It is very simple, and saves alot of frustration later if you actually understand how they work.
Users browsing this forum: No registered users and 86 guests
