It is currently Fri Nov 13, 2026 14:42
 Post subject: LCD doesn't work
PostPosted: Sat Mar 12, 2005 12:57
Hello
I have just finished my lcd-wiring.
Now I have installed the programm and configurated the right controller. ( T 6963C ).
What have I to do now to run the display?
What is the vcl50.bps for ?
And for what do i need the DLPortIO ?
I have just installed the port95nt.exe and with the testing programm from pollin it works fine.
But it doesn't work with lcdinfo
Thx for your help
PostPosted: Sat Mar 12, 2005 14:19
Well if you are sure you have wired your lcd correctly , you need to design a few screens before you will see anything , apart from the goodbye message when you shut down LcdInfo , and if you dont get the goodbye message when you close lcdinfo then you haven't wired or config'd your lcd correctly, simple as that :D
Drop me a mail and i will send you a couple of screens to get you started if you are still getting nothing.
mingingbollock AT dsl.pipex.com
PostPosted: Sat Mar 12, 2005 15:42
DLPortio/port95nt is not needed to run LCDinfo.
I think you didn't make/selected any screens for your controller/size. As ming said at least you should get the 'goodbye' message when you shut down LCDinfo.
PostPosted: Sat Mar 12, 2005 15:55
no, there comes no goodbye screen
but my wireing must be right, because with this test-software it works fine
http://www.pollin.de/service/LCD/120123.zip
but when i run lcd info there comes only bulls***
PostPosted: Sat Mar 12, 2005 17:23
Have you also (double) checked the Pollin pin-layout in the LCDinfo's T6963C driver configuration?
PostPosted: Mon Mar 14, 2005 23:49
Sounds to me like the Pinout for that test program, and the configured pinout for the LCDinfo driver are slightly incompatable. Lucky for you Henri was kind enough to make the drivers configurable.... As Coorz suggested, double check the wiring of the Pollin setup against the config in LCDinfo'd driver config screen. :)
Smart guy that Coorz. :)
