It is currently Sat Apr 17, 2021 10:19
 Post subject: No display
PostPosted: Thu Apr 21, 2005 13:57
Hello,
I have a Optrex DMC40457.
I have download LCDInfo 0.6
I select the driver HD44780(Text only) v0.1 alpha
Then i open the Configure menu: Select size is 40x4 , Mode is 8 bit.
When -> OK i become: "No configuration dialog available."
What do i wrong?
Ben
PostPosted: Thu Apr 21, 2005 19:29
Hmm sounds like you might have found a bug. Sounds like something has not been remembered to change when there was a little interface change for the configuration dialogs.
But even if you get the message it shouldn't matter. Normally you just wouldn't get the message there.
