| Noritake CU20026SCPB-T30A working with LCDInfo?? http://forum.lcdinfo.com/viewtopic.php?f=10&t=2141 |
| Author: | zephyr [ Tue Feb 06, 2007 3:47 ] |
| Post subject: | Noritake CU20026SCPB-T30A working with LCDInfo?? |
Hi.. I have a bunch of these displays. Are they supported in LCDInfo? The controller is a FIPC8367 parallell/serial controller. I have wired it according to my best knowledge, but i only get a underline curson flashing wildly around the display. Here is how i wired it parallel Port: Display (NEC): Pin: Name: Name: Pin: 1 /STROBE -------------- /WR 1 2 D0 -------------- D0 15 3 D1 -------------- D1 13 4 D2 -------------- D2 11 5 D3 -------------- D3 9 6 D4 -------------- D4 7 7 D5 -------------- D5 5 8 D6 -------------- D6 3 9 D7 -------------- D7 1 10 /ACK --o 11 BUSY --o------BUSY 27 16 ---------------- /CS 23 18 - 25 GND ------------o-- GND 2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34 Does this sound somewhat right? Here is datasheet for the displays. http://www.qscomp.cz/Pdf/CU20026SCPB-T30A-01.pdf |
| Author: | Henri [ Sat Feb 10, 2007 2:06 ] |
The closest existing driver is probably the CU20045SCPB-T23A driver. You should get the CU20045SCPB-T23A datasheet and compare the commands to see if they match. |
