It is currently Sun Oct 11, 2026 7:12
 Post subject: stupid plugin question
PostPosted: Wed Nov 26, 2003 22:29
alright, I'm stupid and need help...
How do I get winamp2 support... for some odd reason, I can't see any plugin text for winamp, even with the default screen.xml. how do I load the plugin, what's it called, etc.
PostPosted: Wed Nov 26, 2003 23:28
Have you enabled the Winamp portion of the plugin ?
Like this: http://www.skippari.net/phpBB2/viewtopic.php?t=403 ?
"You need to put the vis_lcdinfo.dll from the package to your winamp/plugins directory and set it as the current visualization plugin in Winamp. You might also want to check Auto execute visualization plug-in on play from Winamp's plugin settings. "
PostPosted: Thu Nov 27, 2003 4:15
but my package hasn't got vis_lcdinfo.dll!
it just has the lcdinfo side winamp_plugin.dll, but none of the support plugs. where do I get them?
PostPosted: Thu Nov 27, 2003 8:40
:oops:
I must have accidentally removed the file from the package.
You can get it here: http://www.skippari.net/lcd/alpha/vis_lcdinfo.dll
Users browsing this forum: No registered users and 51 guests
