It is currently Tue Oct 13, 2026 21:22
 Post subject: LCDInfo startup in Xp
PostPosted: Sun Jun 20, 2004 18:35
Hey guys,
whats the best way to start LCDinfo on bootup in XP? A shortcut to LCDINFO.EXE in the startup folder? or is there another better way. Currently the startup folder idea is not working all the time for me. Sometimes on bootup it works, sometimes it doesnt
Any suggestions would be great.
Ohmstable
PostPosted: Mon Jun 21, 2004 7:15
The 'RUN' key in your registry.
PostPosted: Mon Jun 21, 2004 10:15
Can you be a little more specific? I am not to familiar with windows registry modifying..
PostPosted: Mon Jun 21, 2004 10:28
Startups can be added in this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Add a key to start up LCDinfo. USE AT OWN RISK :?
PostPosted: Tue Jun 22, 2004 5:33
I put that into the registry but its like the first thing that loads up on boot and the lcd doesn't work. I have to exit it and rerun lcdinfo. is there a way i can get it to load last?
PostPosted: Tue Jun 22, 2004 12:18
You could try adding a delay before lcdinfo starts. Something like this was discussed here: http://www.skippari.net/phpBB2/viewtopi ... ight=#2990
The better solution would be a start up delay option in LCDInfo itself like there was in some older LCDInfo version. This will come later.
Users browsing this forum: No registered users and 56 guests
