It is currently Sat Oct 10, 2026 5:43
 Post subject: hello again
PostPosted: Thu Jan 22, 2004 7:01
Hi Henri and everyone,
I had the urge recently to dust off my Noritake 800As and build some cable sets. So now I'm working and ready to get back with LCDInfo. I just wanted to say hi for now, but I'll get some stuff together soon and post some pics etc.
linear
PostPosted: Sat Jan 24, 2004 16:23
Hi :D
First I want to thank you again as without your support LCDInfo most likely wouldn't have Noritake 800 support today. :)
I should also start working to finish build 16 as it is supposed to fix some problems with Noritake 800 and KS0108 displays and vertical placement of images. After the fixes it should be possible to put images freely in any position and they should update correctly.
When you get something done I'm sure everyone will be interested in seeing the results.
PostPosted: Wed Jan 28, 2004 21:05
What version should I be working with, Henri?
Edit: I'm happy to run a pre-alpha if you're looking for bug reports.
PostPosted: Thu Jan 29, 2004 10:03
0.6 build 15 is probably the one to use at the moment and it can be considered pre alpha so if other issues than the already reported are found then I'd like to hear about them.
I don't know if you have seen it already but there is a bugtracker at: http://www.skippari.net/bugtracker/
New bugs can be reported there and if there's any feedback to the already known bugs then just post a followup as that's why the bugtracker has been set up.
Users browsing this forum: No registered users and 154 guests
