It is currently Mon Aug 24, 2026 12:40
 Post subject: Runtime error, why me?
PostPosted: Mon Feb 02, 2004 8:16
Well, I haven't quite completed setting up the hardware part of my graphical LCD (Optrex DMF-5003 w/ White CCFL backlight), so I took the time to work on setting up LCDInfo for the display. First I ran the program to setup the display (T6963C controller, 160x128 screen, 8x8 font, PowerLCD pin-out). Then I went through the busywork of the XML coding (fun). I created a directory for the screen, made a few bitmap background, whipped up a basic outlook. The problem is, when I use the screens.xml file that I typed up, LCDInfo spits out a Visual C++ Runtime Error: "This application has requested the Runtime to terminate it in an unusal way. Please contact the application's support team for more information."
screen.xml:
<screens>
   <screenfile>160x128\pick.xml</screenfile>
   <screenfile>160x128\system.xml</screenfile>
</screens>
pick.xml:
<screen>
   <name>Whypick1</name>
   <action>
      <id>Core.ChangeScreen</id>
      <parameter>System</parameter>
      <delay>5000</delay>
   </action>
      <imagebitmap>160x128\images\pick.bmp</imagebitmap>
      <refresh>500</refresh>
   </item>
</screen>
system.xml:
<screen>
   <name>System</name>
   <action>
      <parameter>Winamp</parameter>
      <delay>5000</delay>
   </action>
   <item type="image" x="0" y ="0">
      <imagebitmap>160x128\images\systemback.bmp</imagebitmap>
   </item>
   <item type="plugintext" x="2" y="36">
      <scrolltype>none</scrolltype>
      <textpos>left</textpos>
      <fieldsize>12</fieldsize>
      <varid>CAMEL.Processor</varid>
   </item>
   <item type="plugintext" x="90" y="36">
      <fieldsize>8</fieldsize>
      <varid>CAMEL.CPUClockFrquency</varid>
   </item>
   <item type="text" x="2" y="44">
      <fieldsize>4</fieldsize>
      <textdata>CPU:</textdata>
   </item>
   <item type="plugintext" x="34" y="44">
      <fieldsize>2</fieldsize>
      <varid>MBM.Temperature.CPU</varid>
   </item>
   <item type="text" x="60" y="44">
      <textdata> C</textdata>
   </item>
   <item type="text" x="2" y="52">
      <textdata>System:</textdata>
   </item>
   <item type="plugintext" x="66" y="52">
      <varid>MBM.Temperature.System</varid>
   </item>
   <item type="text" x="72" y="52">
   </item>
   <item type="text" x="2" y="68">
      <textdata>Uptime: </textdata>
   </item>
   <item type="plugintext" x="66" y="68">
      <varid>uptimed</varid>
   </item>
   <item type="text" x="82" y="68">
      <fieldsize>1</fieldsize>
      <textdata>:</textdata>
   </item>
   <item type="plugintext" x="90" y="68">
      <varid>uptimeh</varid>
   </item>
   <item type="text" x="106" y="68">
   </item>
   <item type="plugintext" x="122" y="68">
      <varid>uptimem</varid>
   </item>
   <item type="text" x="130" y="68">
   </item>
   <item type="plugintext" x="138" y="68">
      <varid>uptimes</varid>
   </item>
   <item type="plugintext" x="2" y="84">
      <scrolltype>left</scrolltype>
      <fieldsize>19</fieldsize>
      <varid>NetStats.AdapterName0</varid>
   </item>
   <item type="plugintext" x="2" y="92">
      <varid>NetStats.Speed0</varid>
   </item>
   <item type="plugintext" x="66" y="92">
      <varid>NetStats.UploadSpeed0</varid>
   </item>
   <item type="plugintext" x="2" y="108">
      <varid>NetStats.AdapterName1</varid>
   </item>
   <item type="plugintext" x="2" y="116">
      <varid>NetStats.Speed1</varid>
   </item>
</screen>
Thanks for the help.
PostPosted: Tue Feb 03, 2004 13:33
I went through that but didn't see anything wrong just by reading it. When I get home I'll test this myself to see if I have the same result. I'm not able to test it with 160x128 screen but I hope that won't have much effect. I have an Optrex 160x128 display waiting and it's already wired except for the negative voltage circuit. I have parts for that too, just need to put it together.
I have not seen that error before but I hope to be able to figure out what the problem is.
PostPosted: Sun Feb 08, 2004 13:13
I got the runtime error solved here. First I copy pasted the files from your post and got the same error.
First thing I noticed is that you had the images like this: "<imagebitmap>160x128\images\systemback.bmp</imagebitmap> " they should be relative to the LCDInfo base directory: "<imagebitmap>screens\160x128\images\systemback.bmp</imagebitmap> "
Then came the runtime error to figure out. I tested many things and took parts of your file out and also ran with debug build of LCDInfo but that didn't reveal anything useful. I noticed that the runtime error came from system.xml and when
   </item>
was in place.
Finally I just took that out and copied the section from pick.xml and it worked. I don't know why it was like that, maybe there was some hidden character causing problems.
I also noticed that you have given the text locations in pixel coordinates in pick.xml. Unfortunately this don't work yet and you need to give them in character coordinates until the truetype font support is included.
PostPosted: Sun Feb 08, 2004 19:43
Thanks a bunch Henri. Now if I can only get the stuff I need to run for my screen working, I'd be in business.
