It is currently Sun Oct 11, 2026 6:32
 Post subject: About graph....
PostPosted: Thu Feb 26, 2004 2:51
Well i'm testing winamp & other graph, and there is a problem:
the winamp doesn't seem to be the reality in show the frequency the bass is too much upper and other frequency were not show as that is should be.
the spectrum bar 2 show nothing :?
the dot spectrum has the same problem with the analyse of the frequency, bass is on saturn when the middle and high frequency are one the sun :s
Cpu graph have an other problem I don't find anything to make this graph at a specific size so it don't show the true activity and the upper CPU activity are not show.
So my question are is there a possibility to resize the graph, spectrum and other? like this parameters: starx, starty, endx, endy.......
For winamp2 status image the pause icon is not show....
And finally will it be a graph like in liquid mp3 ?
£+µ :D thx
PostPosted: Thu Feb 26, 2004 3:01
Scuze me i find your update for winamp spectrum bar 2 work :oops:
The analyze of the frequency are better than the first spectrum but it's always too small, winamp spectrum is the empire state building near the spectrum bar in lcdinfo for the medium and high frequency
For the resize I think this question is stupid forgot it ^^
£+µ :wink:
PostPosted: Thu Feb 26, 2004 18:50
I've noticed the same thing with winamp spectrum myself. I need to look into it. At the moment I'm just taking the values from winamp so maybe I need to do some processing to the data.
To be honest I've no idea what the graph is outputting at the moment as it's not on the "supported" features of LCDInfo yet. It's on my to do list.
PostPosted: Fri Feb 27, 2004 6:01
okay henri so i will wait.
I will use the current.
£+µ :lol:
PostPosted: Fri Oct 08, 2004 1:45
Old post but I havent seen a solution yeat.
A simple log function gives a more powerfull output at higher frequencies.
I added this line
value += value*(log(col*col+1));
to the winamp2_plugin (plugin.cpp) at row 132
Theres no sience behind my calculation.
PostPosted: Sat Oct 09, 2004 11:30
I have added the fix from Daniel to the plugin: http://www.skippari.net/lcd/alpha/plugi ... plugin.dll
PostPosted: Sat Oct 09, 2004 21:51
I will test when back to my house (hollyday powa for a week ^^)
£+µ
PostPosted: Sun Oct 10, 2004 12:45
I replaced the old winamp2 plugin with the new one but now LCD info wont start again. I get an error @ startup like "LCDINFO.exe has generated a error and wil be closed bij windows."
edit 1
It happend with build 17 I havend tested it with build 18
edit2
it works with build 18
as we say is in Dutch: prutst vrolijk aan zijn LCD.
or in English : stumbles happy on with his LCD. :P
Users browsing this forum: No registered users and 168 guests
