It is currently Mon Oct 12, 2026 18:50
PostPosted: Sat Jun 19, 2004 3:28
I was wondering if the source code for LCDInfo was available? As i would be able to make my own changes or perhaps contribute.
I'm not a particularly good coder (well i havent done any real codng in a while) but i'm sure I (and many others) could get alot from being able to read/ change the source to suit our purposes. And also a much greater understanding of how it all works etc.
Just wondering.
Reuben.
PostPosted: Sun Jun 20, 2004 10:42
Maybe if you would be more specific in what you'd like to do we could find out if it's the full source code or just the plugin sdk that is needed to do that.
So with more information and being more specific we can probably find the best solution.
PostPosted: Wed Jun 23, 2004 7:24
Sorry, i just figured i could get a better understanding of lcdinfo if i could read the source code of it.
And other things like for example, i could have done a quick hack for the PCD8544 driver to allow me to use my own wiring.
PS: when can we expect the custom wiring for PCD8544 to be implemented?
(a round-about guess)
PostPosted: Mon Jun 28, 2004 17:40
No need to be sorry of anything ;) Full sources are not currently publicly available but this is under consideration.
Ok, for custom PCD8544 wiring you can try this: http://www.skippari.net/lcd/alpha/pcd8544_driver.dll
I haven't yet tested it myself so it might contain some bugs or not work at all.
PostPosted: Tue Jun 29, 2004 3:46
Thanks, but that crashes LCDInfo... :(
The log doesnt tell why it chashes, but it's right after it loads the DLL.
Ohh well, you said that it may not even work. :wink:
I'm thinking of writing a program using serdisplib (i'm sure you've heard of it)
to display text...this is for my server (linux) and it would've been a bother to have to move the LCD from one to the other.
thanks anyhow.
PostPosted: Tue Jun 29, 2004 9:55
Hmm, the crash wasn't expected. As I said I hadn't tested it but I did some testing and ran it with LCDInfo to test how the config screen works etc. but I didn't have any display connected so I wasn't able to confirm if it outputs anything.
I'll have a look into this.
PostPosted: Tue Jun 29, 2004 10:07
Well, i'm running win98SE and it seems to crash due to the PCD driver as you can see here:
LCDINFO caused an invalid page fault in
module PCD8544_DRIVER.DLL at 0167:013f25a1.
Registers:
EAX=0000003e CS=0167 EIP=013f25a1 EFLGS=00010206
EBX=780c2600 SS=016f ESP=0069f8cc EBP=01051490
ECX=0000009c DS=016f ESI=007c53d0 FS=2c5f
EDX=00000000 ES=016f EDI=00000000 GS=0000
Bytes at CS:EIP:
88 04 17 8b 4e 30 8b 56 2c 8a 1c 39 8b 4e 74 8a
Stack dump:
00000001 0046d058 007c6aa0 007c5934 780c26b5 00000000 007c5934 780c26b5 004031ec 00000000 0045a190 00000000 00000000 0069fbae 0069fa24 007d9edf
The DLL is PageFaulting.
Users browsing this forum: No registered users and 47 guests
