It is currently Tue Aug 25, 2026 5:18
 Post subject: Bug in latest build?
PostPosted: Thu Dec 16, 2004 21:47
I tried the latest build, and between the older version (ver 6) and this build, I am seeing a difference in the way my LCD display gfx. It seems that the latest version does not deal with a 128x128 display correctly. It seems to cutoff the first few pixels on the left hand side of the display, the previous build does not do this.
I am using a 128x128 display with a T6963C controller.
PostPosted: Fri Dec 17, 2004 6:20
Hmm... that's strange, I haven't changed anything in the driver section and I have a T6369C 240x128 and that seems to work fine.
Here is the source:
http://users.on.net/~krakken/LCD/lcdinfo_source.zip
PostPosted: Fri Dec 17, 2004 6:34
strange, I tried a few times modifying my xml file thinking that was the problem, but got no where, as soon as I went back to the older version things looked correct.
PostPosted: Fri Dec 17, 2004 8:49
Can you shed any light on this Henri? The only thing I can think of is the fact that it's compiled on VC++ .NET 2003 rather than 6?
Henri, I told you about the compiler errors I was getting (the iterator errors) do you think that when I changed it it would have messed something up? The thing I don't understand is that it seems to work fone for me.
PostPosted: Fri Dec 17, 2004 19:13
If it helps I can send you my config files, they are set up for a 128x128 display.
PostPosted: Thu Dec 30, 2004 21:12
Yes as the driver is still the same there shouldn't be any change causing problem there. But maybe it is something about VC++ .NET 2003 handling something differently compared to VC6. One more reason for me to get newer VC to test this.
