It is currently Sat Nov 21, 2026 20:41
PostPosted: Mon May 09, 2005 14:44
Can someone please program a plugin to pick up the temps and clockspeeds etc for my Nvidia-6800GT , Riva tuner looks to be the best at the moment , http://www.guru3d.com/rivatuner/ or an hack for MBM.
pretty please with a cherry on the top :D
cheers :D
PostPosted: Tue May 10, 2005 18:10
Any idea how to read the data ? Is there some kind SDK available for the program ?
PostPosted: Tue May 10, 2005 18:28
I haven' t a clue mate :oops: but i will ask in the riva forum , there has got to be more than me wanting this , see if i can get some answers for you
- does that mean you will take the job on ? :D :D :D :D :D :P :P :P
cheers Henry
Edit: the tools are there , i will point you in the right direction when i find the way :D , sounds easy :D
http://forums.guru3d.com/showthread.php ... genumber=2
PostPosted: Wed May 11, 2005 10:45
Well after doing a little digging it appears that a MBM hack should be possible , quote-
"The same applies to this feature. SDK/RTHMSharedMemorySample was added to RT about a half year ago too. _Special_ due to certain LCD manufacturers requests, to allow them to create their own software displaying RT's monitoring statistics on LCD.
Any man able to program can use this SDK/sample and can easily create MBM plugin."
The Sdk is located in the installation folder of rivatuner , so all you clever programming types can take a crack at it..PLEASE .
Henry i really hope you have a nvidia card ?
dload link- http://downloads.guru3d.com/download.php?det=163
cheers and good luck :D
Edit : speedfan would do too :D http://forum.lcdinfo.com/viewtopic.php?t=922 :lol:
PostPosted: Mon May 16, 2005 22:36
Thanks for finding the information.
Looked into the SDK and it has all the needed information to make a plugin.
I will try to have a plugin available soon.
PostPosted: Tue Jan 31, 2006 19:33
Thanks a lot! Also I would need a such plug-in since I'm planning to build a little something with a display that uses the KS0108 controller, and would therefore use your little clever program to power it :)
