| WTD: Nvidia 6800GT Plugin - Riva Tuner http://forum.lcdinfo.com/viewtopic.php?f=13&t=1194 |
| Author: | mingingbollock [ Mon May 09, 2005 14:44 ] |
| Post subject: | WTD: Nvidia 6800GT Plugin - Riva Tuner |
Can someone please program a plugin to pick up the temps and clockspeeds etc for my Nvidia-6800GT , Riva tuner looks to be the best at the moment , http://www.guru3d.com/rivatuner/ or an hack for MBM. pretty please with a cherry on the top cheers |
| Author: | Henri [ Tue May 10, 2005 18:10 ] |
Any idea how to read the data ? Is there some kind SDK available for the program ? |
| Author: | mingingbollock [ Tue May 10, 2005 18:28 ] |
I haven' t a clue mate - does that mean you will take the job on ? cheers Henry Edit: the tools are there , i will point you in the right direction when i find the way http://forums.guru3d.com/showthread.php ... genumber=2 |
| Author: | mingingbollock [ Wed May 11, 2005 10:45 ] |
Well after doing a little digging it appears that a MBM hack should be possible , quote- "The same applies to this feature. SDK/RTHMSharedMemorySample was added to RT about a half year ago too. _Special_ due to certain LCD manufacturers requests, to allow them to create their own software displaying RT's monitoring statistics on LCD. Any man able to program can use this SDK/sample and can easily create MBM plugin." The Sdk is located in the installation folder of rivatuner , so all you clever programming types can take a crack at it..PLEASE . Henry i really hope you have a nvidia card ? dload link- http://downloads.guru3d.com/download.php?det=163 cheers and good luck Edit : speedfan would do too |
| Author: | Henri [ Mon May 16, 2005 22:36 ] |
Thanks for finding the information. Looked into the SDK and it has all the needed information to make a plugin. I will try to have a plugin available soon. |
| Author: | NewToasted [ Tue Jan 31, 2006 19:33 ] |
Thanks a lot! Also I would need a such plug-in since I'm planning to build a little something with a display that uses the KS0108 controller, and would therefore use your little clever program to power it |
