It is currently Mon Sep 28, 2026 0:33
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: TimeInfo plugin
PostPosted: Tue Aug 10, 2004 14:46
Thomas Jäger has made a time plugin for LCDInfo. Good work Thomas :D
You can get it here: http://www.skippari.net/lcd/alpha/plugi ... plugin.dll
What's available:
TimeInfo.Hour - Name:System Time Hours (00-24)
TimeInfo.Minute - Name:System Time Minutes (00-59)
TimeInfo.Second - Name:System Time Seconds (00-59)
TimeInfo.Time - Name:System Time (hh/mm/ss)
TimeInfo.Day - Name:System Date Month (00-12)
TimeInfo.Month - Name:System Date Day (00-31)
TimeInfo.Year - Name:System Date Year (00-99)
TimeInfo.Date0 - Name:System Date (dd/mm/yy)
TimeInfo.Date1 - Name:System Date (mm/dd/yy)
TimeInfo.Weekday - Name:System Weekday (Monday-Friday)
Thomas also sent me these pictures:
There is analog clock now also:
I was able to implement a analogue clock into
the time plugin. All you need is a background picture what works as a dial
for the clock. I have attached 3 sample backgrounds. Just rename one of them
to "Clock_Background.bmp" and copy it to the LCDInfo folder. There are no
adjustments to be made, since the pointers adapt to the size of the bitmap
automatically. Just make sure that the height and width of the bitmap are
the same, in case you want to make your own background. Then just add the
following term to your "clock screen" and adjust the position:
<item type="pluginimage" x="5" y="9">
<imageid>TimeInfo.Analog</imageid>
<refresh>100</refresh>
</item>
This should bring up a clock screen as the one in the attached photo.
http://www.skippari.net/lcd/alpha/plugins/CLOCK_128x64_V2.bmp
http://www.skippari.net/lcd/alpha/plugins/Clock_Background_32x32.bmp
http://www.skippari.net/lcd/alpha/plugins/Clock_Background_52x52.bmp
http://www.skippari.net/lcd/alpha/plugins/Clock_Background_64x64.bmp
PostPosted: Wed Aug 11, 2004 1:51
hello
error opening dll: D:\lcdinfo\time_plugin.dll
23:54:21:203 LoadLibrary() error: Le module spécifié est introuvable.
PostPosted: Thu Aug 12, 2004 11:14
Hmm, seems like the plugin dll is built in debug mode and your system doesn't have the debug versions of MS runtimes.
I'll inform Thomas about this.
PostPosted: Thu Aug 12, 2004 12:22
There's now Release build available that should fix the error I hope. Also analog clock is now included.
PostPosted: Thu Aug 12, 2004 12:42
Thanks Thomas! I be spending more time making screens now, will post a pic soon.
PostPosted: Thu Aug 12, 2004 15:45
Henry sill linked to an old version of the plugin. The old version will only work when VC++ is installed your computer, since I accidentally did not turn off the debug mode. The new version must be 36KB in size, the old one is 125KB. Please wait until Henry had the chance to update the link to the new version.
Regards
Thomas
PostPosted: Fri Aug 13, 2004 10:29
I just chcked the above link for the plugin and it is the right version now !!!
Regards
Thomas
PostPosted: Sat Aug 14, 2004 16:11
Works great, any chance of having the months also in 'normal' name mode, just like TimeInfo.Weekday - Name:System Weekday (Monday-Friday) ?
PostPosted: Sun Aug 15, 2004 23:19
Thomas,
I'm getting extremely high memory usage (400mb+) after running LCDinfo with a screen that uses your plugin for a very long period (10+ hours), after that it just terminates LCDinfo and hangs on the time.info screen.
No error messages.
FIY i have a clock_background.bmp sized 200x200 pixels.
PostPosted: Mon Aug 16, 2004 8:48
Hi coorz,
- it looks like as some memory does not get released. I need to talk to Henry about this. :cry:
- I guess having the month as a name (January, February...) should be no problem. :)
I will post a message as soon as the changes are done.
Regards
Thomas
PostPosted: Mon Aug 16, 2004 9:32
Thanks :D
PostPosted: Tue Aug 17, 2004 0:06
Thomas,
Works ok now. Memory usage bug is gone.
Thanks for your effort :wink:
(pic coming tomorrow, forgot my cam :roll: )
PostPosted: Tue Aug 17, 2004 13:47
Thomas,
look in this topic on the clock i made. Nothing really special for now, unti i get some wacko idea for it :wink:
PostPosted: Tue Aug 17, 2004 16:31
Hi coorz,
nice work. It looks very impressive. :!: I have asked Henry to update the link to point to the new version of the plugin. At the moment it is still the faulty version :( .
Regards
Thomas
PostPosted: Tue Aug 17, 2004 21:34
Sorry, my attention has been on some other things and it took a while to get the file updated. It should be updated now.
