| Network statistics http://forum.lcdinfo.com/viewtopic.php?f=13&t=402 |
| Author: | Henri [ Sat Nov 08, 2003 15:25 ] |
| Post subject: | Network statistics |
Variables available: NetStats.Adaptername0 Adapter name NetStats.MTU0 Adapter MTU NetStats.Speed0 Adapter theoretical speed NetStats.TotalDownload0 Adapter total download NetStats.TotalUpload0 Adapter total upload NetStats.DownloadSpeed0 Adapter current download speed NetStats.UploadSpeed0 Adapter current upload speed By changing the number at the end of variable you can get statistics for different adapters on the system. All found network interfaces are listed to log.txt. All info is read from this struct so if there's need more variables could be added. Code: typedef struct _MIB_IFROW {
WCHAR wszName[MAX_INTERFACE_NAME_LEN]; DWORD dwIndex; // index of the interface DWORD dwType; // type of interface DWORD dwMtu; // max transmission unit DWORD dwSpeed; // speed of the interface DWORD dwPhysAddrLen; // length of physical address BYTE bPhysAddr[MAXLEN_PHYSADDR]; // physical address of adapter DWORD dwAdminStatus; // administrative status DWORD dwOperStatus; // operational status DWORD dwLastChange; // last time operational status changed DWORD dwInOctets; // octets received DWORD dwInUcastPkts; // unicast packets received DWORD dwInNUcastPkts; // non-unicast packets received DWORD dwInDiscards; // received packets discarded DWORD dwInErrors; // erroneous packets received DWORD dwInUnknownProtos; // unknown protocol packets received DWORD dwOutOctets; // octets sent DWORD dwOutUcastPkts; // unicast packets sent DWORD dwOutNUcastPkts; // non-unicast packets sent DWORD dwOutDiscards; // outgoing packets discarded DWORD dwOutErrors; // erroneous packets sent DWORD dwOutQLen; // output queue length DWORD dwDescrLen; // length of bDescr member BYTE bDescr[MAXLEN_IFDESCR]; // interface description } MIB_IFROW,*PMIB_IFROW; |
| Author: | Briseur [ Fri Dec 26, 2003 1:40 ] |
| Post subject: | Re: Network statistics |
Hello! Would be it possible to have a plugin for emule. I precise in graph!!! |
| Author: | DarkElf [ Sat Dec 27, 2003 4:08 ] |
you too wan't this?!? |
| Author: | Ch3p4cK [ Fri Jan 30, 2004 13:42 ] |
| Post subject: | How? |
How can I use this plugin ?? It isn't a file! |
| Author: | Henri [ Fri Jan 30, 2004 17:18 ] |
The plugin file is included in the LCDInfo 0.6 package. When you run LCDInfo 0.6 all variables available are printed to the log.txt file in the LCDInfo directory. There you can also find the NetStats.* variables. They don't have describing names at the moment so you need to test yourself which variable corresponds to which network adapter. Then you can just put that variable in the screen configuration file. |
| Author: | mingingbollock [ Thu Apr 22, 2004 17:32 ] |
Just noticed a little quirk in this plugin, when your d/load total reaches 2000meg it then adds a minus sign to the front and starts counting backwards, 1999, 1998 etc, not a problem , but mighty confusing first thing in the morning. cheers minging |
| Author: | Henri [ Sat Apr 24, 2004 10:10 ] |
I'll see if there is a bug in my plugin. Even if the problem comes from my plugin the limit of this counter will be 4000MB because MS is using the 32-bit DWORD used in the struct showed in the first post. To get past this the plugin should somehow detect when the counter overruns and then use this information to give correct values. |
| Author: | mingingbollock [ Tue May 11, 2004 13:01 ] |
Sorry to be a pain again Henry lol, another little quirk, the netstats plugin doesn't update, in other words you have to either log online Before you have started lcdinfo or close lcdinfo and restart it to get my dsl stats, hope that makes sense lol thanks again Henry and keep up the excellent work minging |
| Author: | Henri [ Wed May 12, 2004 21:32 ] |
Added to bugtracker... |
| Author: | croc4 [ Mon Dec 06, 2004 23:16 ] |
| Post subject: | Ip addr in Netstats plugin |
It would be good to have the IP addr available from the netstats plugin |
