It is currently Fri Oct 16, 2026 18:34
 Post subject: winamp problem
PostPosted: Thu Aug 05, 2004 21:51
Hi to all, this is my first post, and sorry for my english...
I have some problem with the winamp plugin I use winamp 5.x but I have the same problem with 2.80 vers.):
- why the spectrumbar2 doesn't work? I can't visualize noting...
- why the spectrumbar doesn't show all the frequency range but only the left frequency (and not so high)
- how could freeze the screen when winamp is playing (I discover the winamp.playing but I don't understand the sintax)?
thanks for your patience and great work!!
PostPosted: Sun Aug 08, 2004 19:19
noone can help me? please....
PostPosted: Sun Aug 08, 2004 23:59
- Have you set the right starting X, Y coordinates for Winamp2.SpectrumBar2?
- Winamp2.SpectrumBar indeed only shows one channel, i think Henri should comment on this :wink:
Also sensitivity is something that is not implemented yet in the plugin i believe.
PostPosted: Mon Aug 09, 2004 20:53
ok, thanks for your reply...
coorz wrote:
- Have you set the right starting X, Y coordinates for Winamp2.SpectrumBar2?.
yes, to be sure i could try with the original winamp-screen
:cry: :cry:
PostPosted: Tue Aug 10, 2004 14:53
Please make sure that that the spectrum fits inside the screen area. If it doens't LCDInfo doesn't show it. SpectrumBar2 is 128x32 pixels in size and depending of your display size this might be a problem.
:cry: :cry:
Yes, the visualizations are quite simple at the moment. I hope to improve this later. Something like LiQuiD-MP3 quality would be great but I can probably only dream of that but it should be possible to make the LCDInfo visualizations somewhat better without too much work.
