It is currently Wed Mar 03, 2021 8:08
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 04, 2004 23:31
great plugin
PostPosted: Sat Feb 07, 2004 20:21
ok thank you. i have looked in the log.txt file and found the variables.
just to let you know, i didn't find any information about the variables available in the readme file!
Unfortunately, it worked for a few days and today, i don't why, the show of variables for wmp is not working anymore. The visualisation work but not the rest... :(
in the log i saw this :
error getting interface: C:\...\lcdinfo_test\WinIo.dll
This file exist, so is the pb coming from this file?
PostPosted: Sun Feb 08, 2004 13:28
"error getting interface: C:\...\lcdinfo_test\WinIo.dll " is nothing to worry about. LCDInfo tries to load every dll in the directory and as WinIo.dll is not LCDInfo plugin it can't be loaded.
Have you tried reinstalling the plugin in WMP itself ?
PostPosted: Mon Feb 09, 2004 21:30
:| i don't work with winio...
did you downloaded the version on my ftp? it's the newest version
PostPosted: Mon Mar 29, 2004 12:48
Hi DarkElf I'unfortunatly also be unable to run WMP9 with your plug-in under w98SE :cry: !
w98 run out (se bloque) when I select the plug-in in WMP. :cry:
I'sent you the details on the e-mail you put in the readme file.
Thanks for this plug-in
PostPosted: Sat Jan 15, 2005 1:53
I see this plugin is for wmp 9. Is there anyone trying to make it work with wmp 10? All i get what using the spectrumbar for wmp plugin is a line at bottom. I would really rather use wmp that winamp. If anyone is working on one I'd like to test it. Thanks for all your work!
PostPosted: Sat Jan 15, 2005 2:57
It works on 10... But you have to have the vizualisation running in the open window. There are other threads about this problem, but being a lazy saturday morning and too hot and muggy here... I couldn't be bothered search for them for you. Just open the vis, and it should work... works fine for me.
PostPosted: Sat Jan 15, 2005 5:35
I got it thanks.
