It is currently Thu Oct 08, 2026 21:56
PostPosted: Mon Mar 29, 2004 23:49
8O
www.hypertransport.de/icq_plugin.rar
see log.txt for the vars if you want more vars like gender, city, email etc let me hear .....
the ipadresses are animated so they are little blurry.... :cry:
PostPosted: Sat Apr 03, 2004 16:19
Hi Relampago, I tried your ICQ plugin under XP and it works well, unfortunatly he doesn't under w98 :cry:
thanks a lot for this plugin.
PostPosted: Sun Apr 04, 2004 3:09
good to hear....
i will have alook on the 8 problem
PostPosted: Mon Apr 05, 2004 10:39
Thanks, tell me if you need more details. I know that my sys isn't too sure :?
Otherwise nice screen :P
Well done !
PostPosted: Mon Apr 05, 2004 15:14
please rename icq_plugin.dll to icq_plugindebug.dll
and post what the "debugger" is telling on startup...
PostPosted: Mon Apr 05, 2004 21:15
It open a DOS window with this "Successfuly logged into your ICQ ;-) but just after I got :
LCDINFO a causé une défaillance de page dans
le module KERNEL32.DLL à 0167:bffa269b.
Registres :
EAX=00000025 CS=0167 EIP=bffa269b EFLGS=00010202
EBX=00000000 SS=016f ESP=006cf790 EBP=006cf790
ECX=00000000 DS=016f ESI=01ac0e80 FS=522f
EDX=00000000 ES=016f EDI=01466575 GS=0000
Octets à CS : EIP :
89 01 b8 01 00 00 00 5d c2 14 00 55 8b ec 6a 20
État de la pile :
008f5a88 01451e79 00000034 01466574 00000025 00000000 00000000 0049b420 01ac0e80 00190050 00000000 00000007 004f0000 00500018 01460019 01452a83
I also get that in the LCD log info
19:15:43:940 C:\WINDOWS\Bureau\lcd_info Build 16\WinIo.dll
19:15:43:940 Not valid LCDInfo plugin: C:\WINDOWS\Bureau\lcd_info Build 16\WinIo.dll
19:15:43:940 C:\WINDOWS\Bureau\lcd_info Build 16\wmp_plugin.dll
19:15:43:940 C:\WINDOWS\Bureau\lcd_info Build 16\zoomplayer_plugin.dll
19:15:43:940 C:\WINDOWS\Bureau\lcd_info Build 16\zworld_op6400_driver.dll
19:15:43:940 C:\WINDOWS\Bureau\lcd_info Build 16\ICQMAPI.dll
19:15:44:0 Not valid LCDInfo plugin: C:\WINDOWS\Bureau\lcd_info Build 16\ICQMAPI.dll
19:15:44:0 C:\WINDOWS\Bureau\lcd_info Build 16\icq_plugindebug.dll
19:15:44:0 No more plugin .DLL files
Does it help ?
PostPosted: Tue Apr 06, 2004 7:03
yes that helps a bit :)
PostPosted: Sat Sep 04, 2004 11:42
where do i put the icq_plugin.dll and ICQMAPI.dll file?
PostPosted: Tue Sep 07, 2004 12:07
To the LCDInfo root directory(same as where lcdinfo.exe is).
PostPosted: Thu Nov 25, 2004 20:56
Hi @ all!
Can somebody make it possible to make it on a screen 128*64 without the icq numbers?
Thank you!
Gruss
Bullrich
PostPosted: Sun Dec 05, 2004 17:07
You can make a 128x64 screen yourself by editing for example Relampago's 320x240 screen by removing unnecessary variables and moving things and probably making a smaller background image.
Users browsing this forum: No registered users and 424 guests
