It is currently Sat Nov 14, 2026 16:11
 Post subject: emule plugin
PostPosted: Sat Dec 27, 2003 4:12
here is a fast way to make a emule plugin: check the online signature under emule
and then use the file onlinesig.dat
inside there is a few things like:
connected
serveur name
serveur ip
current number client
current up
current down
example:
1|Server 195.245.244.243:4661|195.245.244.243|4661
0.0|10.7|76
PostPosted: Sat Dec 27, 2003 12:20
Relampago made emule plugin for the previous LCDInfo version so that should be easy to port for new LCDInfo.
PostPosted: Sat Dec 27, 2003 12:50
I know not to do plugin!!!
I debut! :?
PostPosted: Sat Dec 27, 2003 21:59
I debut! :?
The first thing to do is to find out if Relampago wants to convert his plugin for new LCDInfo so there wouldn't be unnecessary duplicate work.
PostPosted: Tue Jan 06, 2004 1:01
plugin (finally) done....
http://www.ifrance.com/Dark-Elf/emule.zip
PostPosted: Tue Jan 06, 2004 14:17
Good work. :) ( haven't tested anything but I believe in your skills to make a working plugin ;) )
I have had the sources for Relampago's old emule plugin for some days but didn't have time to work on them. But now you have made the plugin so I don't have to think about it anymore :)
PostPosted: Tue Jan 06, 2004 14:21
yes but maybe his plugin is better, mine need to use the signature file :?
but it work and fine :)
already tested by a friend
and betatested it for 3h hours
and it run for 6h without a problem (no mem eating this time ;))
but i will improve it tonight... because some people were very vexating saying lcdhype is better :evil: Will try to add some graphic bar tonight :p
PostPosted: Tue Jan 06, 2004 14:39
Hi
good Work :D.
The only thing i added was the username from the inifile and the emuleversion if i remember correctly. And used some registrysearch for the signature so the user has not to care about were emule is installed.
PostPosted: Tue Jan 06, 2004 14:43
sorry, not good enought in vc++ to do a registry search :oops: , in vb it's ok but nto in vc++
good idea the username :wink:
PostPosted: Tue Jan 06, 2004 15:02
ask henri for the source :D
PostPosted: Wed Jan 07, 2004 1:39
no, it's your work :wink: , i have respect for others work :)
updated my plugin, now it has got 3 pictures: 2 verticals bars & 1 histrogram of the up & down
EMULE.upbar
EMULE.dlbar
EMULE.histo
same adress to download it ;)
PostPosted: Wed Jan 07, 2004 22:36
As I'm not using Emule myself I haven't been able to test the plugin but something I was wondering is what size images are the bars and histograms ? This might be good to know when making screens.
 Post subject: stat emule!!??
PostPosted: Thu Mar 11, 2004 23:56
Good day, I have an info on the subject of the stat of the mule!! For infos given by: EMULE.upbar EMULE.dlbar EMULE.histo his evil étalonner, this is to say that those here are to saturate dice that one ateint more of 50KO in download, how can one the étalonner to post the debit has more
of 50KO?? thank-you in advance;)
PostPosted: Fri Mar 12, 2004 19:38
dark pkoi tu lis pas la valeur de base de registre plutot?
in english ^^
Dark why you couldn't read the registry entry?
:lol:
£+µ :D
PostPosted: Sat Mar 13, 2004 0:59
A small soluce?? :?
