It is currently Wed Nov 04, 2026 23:06
PostPosted: Sat Feb 04, 2006 13:10
hello,
is someone can tell me is it is possible to make a driver for this very nice lcd ?
PostPosted: Mon Feb 06, 2006 13:51
In some way probably yes but that number alone doesn't tell much. You should try posting some datasheets and all information you can find about the display and anything related.
PostPosted: Sun Feb 12, 2006 13:09
here some specs about the controleur
ftp://ftp.promate.com.tw/au/UPS051%20Ver%202.pdf
and the lcd
http://homepages.nildram.co.uk/~displaze/PDF/LCD/AU%20Optronics/A015AN02V1.pdf
PostPosted: Sat Mar 25, 2006 15:22
Looks like the datasheets give enough information to use the display. But it won't be as simple as just wiring to LPT port and making couple lines of code. Probably need to do some additional hardware too.
LCDInfo provides the interface for making your own drivers so if you can't do it yourself based on the information in those documents you're probably out of luck...
