It is currently Fri Oct 23, 2026 2:30
 Post subject: SED1565 - Nokia 7110 Lcd
PostPosted: Sun May 02, 2004 4:58
Is possible add driver for Nokia 7110 Lcd in Lcdinfo?
It´s 96x48 pixels and SED-1565 controller.
---=[ Junior ]=---
www.lcdmania.net
PostPosted: Mon May 03, 2004 22:41
It's possible but I don't have display with SED1565 controller.
PostPosted: Mon May 24, 2004 23:39
SED1565 driver is coming.
Here's some useful information.
First the pinout:
http://sandiding.tripod.com/nokialcd7110.html
pin1 Temp sensor 47k (at 25C)
pin2 _CS
pin3 Speaker_p
pin4 D/_C
pin5 SCLK (max. 3.2MHz at Vlogic=+2.8V)
pin6 Speaker_n
pin7 On/Off
pin8 Led -
pin9 Led +
pin10 Gnd
pin11 Gnd
pin12 Vlogic (+ 2.8V)
pin13 SDATA
pin14 _RESET
For the interface this schematic can be used as a base:
http://www.skippari.net/phpBB2/viewtopi ... =2456#2456
I connected the CS, DC, SCLK, SDATA and RESET to LPT pins, Vlogic to +3.3v and GND to ground. There's no Vout in this display.
Driver coming later.
PostPosted: Wed Jun 09, 2004 17:13
Here's first version of the driver that I made few weeks ago. It contains some drawing bugs but I didn't want to delay this further.
http://www.skippari.net/lcd/alpha/sed1565_driver.dll
PostPosted: Sat Jul 17, 2004 22:06
There is bug in driver wchich is causing strange interactions between background bitmap and plugintext type items.
If you are interested in developing this driver i can provide more details.
PostPosted: Thu Jan 13, 2005 1:51
Drawing bugs are now hopefully fixed. Updated driver here:
I haven't tested this with a real display so please report if there are any problems.
PostPosted: Thu Jan 13, 2005 4:38
Wow Henri,
You have been busy... 3 additional drivers in the space of 12 minutes. ;) No wonder I changed over to using LCDinfo. ;)
PostPosted: Tue May 02, 2006 23:40
Hi Michael,
I has Nokia 7110 Lcds, and i would like test it with MyLcd software.
The problem is i don´t know how to compliler MyLcd software for Windows.
There are a How to for compiler it?
---=[ Junior ]=---
www.lcdmania.net
