It is currently Sun Sep 27, 2026 18:53
PostPosted: Fri Oct 07, 2005 19:27
hi henri,
i get a new vfd NEC FC20X2JA-AB ,it Compatible with Noritake CU20026SCPB-T30A ,first i will test in serial interface not work
and i change try in pararell ,it work!! , i use circuit t23a from here ,overall timing not change ,and it can display character on screen , but not completely ,you can see that my picture
maybe control command such as "clear screen" or another commnad , can't work
i see in datasheet in T30a ,it's different form t23 in pin A0 ,if use write a command ,you will active A0
Can you add t30a in your noritake t-series or you can share this driver for i contribute to t30a
thank you
datasheet for t30a
http://www.maltepoeggel.de/html/vfd/fc20x1sa.pdf
http://www.maltepoeggel.de/html/vfd/fc20x2ja.pdf
form http://www.maltepoeggel.de/html/vfd/
PostPosted: Sat Oct 08, 2005 7:28
:D
i have read all in datasheet
clr command in t30a use 0x1C but in t23a use 0x1E,
and about in active high in a0 for command data ,you can set cursor position.
