It is currently Wed Mar 03, 2021 14:42
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jun 16, 2004 18:25
yes I have.
I also, used henris preset.
nothing.
I wonder if its noise by needing pull-up resistors, or there just isnt enough drive on the parallel port
PostPosted: Wed Jun 16, 2004 20:08
Does anything happen if you run this:
http://www.skippari.net/lcd/alpha/311_test.zip
It is supposed to print text "test" to the screen and also a vertical line about in the middle of the screen.
PostPosted: Thu Jun 17, 2004 19:43
nope. All it does is open a dos window, and then close
PostPosted: Thu Jun 17, 2004 19:44
also, I didnt run that on the same puter. This is another puter I ran "test" on, and it didnt work. its a wiring or a noise/display problem.
i dunno.
what gets me, is I put it in self-test mode, and the noritakes self-test runs on the display.
PostPosted: Thu Jun 17, 2004 19:47
SHIT! GOD DAMN IT!! MY FUCKING LIFE IS A FUCKING NIGHTMARE.
I cant win or lose man. it fucking fell off of the desk, because the parallel cable pulled it to ground, and the display shattered.
im so fucking pissed.
PostPosted: Thu Jun 17, 2004 19:52
sorry for the vulgar language, Im just blowing off steam.
I cant win for loose man.
first my golf cart is gone, then my 500 dollar LCD projo bulb dies, and now my VFD is shattered. What next??
PostPosted: Thu Jun 17, 2004 20:13
mbates14 wrote:
What next??
You win the lottery?
Relax, there are worse things in life.
PostPosted: Fri Jun 18, 2004 17:14
but a dead lcd isnt really a thing to worry about..
PostPosted: Sun Jun 20, 2004 2:21
Hey, its too late now, but I found my problem. i wish I can kick myself in the head over this one.
I made my wiring harness from an old floppy ribbon. well, I pulled off an unused connector halfway down the ribbon, and it leaves those nasty holes from the punch down.
I paid no mind to that, and after the display broke, I noticed that it had pulled a connection on the WR. duh, so i cut the ribbon there, and im going to make a new one.
PostPosted: Wed Jul 28, 2004 2:04
hey I got my new display in, and it works. but, none of the images are showing.
the text is working, and the spectrum is showing, but the spectrum looks weird, and it doesnt go al the way across. only half way.
help?
PostPosted: Wed Jul 28, 2004 2:14
help?
You mean the fullsized spectrumbar? Just exit and restart LCDinfo, i have that too. Also the second part of the bar sometimes gets 'stuck', like it doesn't get refreshed. A little bug i think :? .
PostPosted: Wed Jul 28, 2004 6:06
That doesnt solve any problems.
the spectrum is only 1 pixel wide. and only covers half the display.
in your skins, the bar is like 5 or 6 pixels wide, and fills the entire screen.
PostPosted: Wed Jul 28, 2004 6:56
I figured it out.
I have a question, is there a way to beef the spectrum sensitivity up? it looks kinda flat.
also, the spectrum is jerky and slow. Is there a way to speed it up?
PostPosted: Wed Jul 28, 2004 9:48
Let us know how 'you figured it out'. I am curious to know what should cause yours to behave differently than mines. Since we basically have the same setup.
You can turn on the equalizer in WinAmp to make the spectrumbar more sensitive.
PostPosted: Wed Jul 28, 2004 18:07
those test skins that you had posted here didnt load the bmp. i made it load the bmp, How do you make those btw?
also, the spectrumbar is only half of the screen. its like 64x32 pixels wide.
if I use spectrumbar2, its fills the whole display.
is there a spectrum bar 3?
