It is currently Sun Jul 06, 2025 1:59
 Post subject: RS-232 LCD
PostPosted: Tue Jun 22, 2004 14:54
I have a KS1080 LCD with a RS-232 -> LPT converter board. Is there any LCD's that LCDInfo support that runs of the COM port? Is there any way of implementing a COM port lcd in the current version of LCDInfo?
Rudi Grobler
PostPosted: Thu Jun 24, 2004 10:47
Yes there are already several serial lcd's supported by LCDInfo so what you have in mind is possible.
PostPosted: Tue Jun 29, 2004 8:20
A friend of mine designed a board that takes a serial command and convert it to a 8 bit ttl signal. It supports 16 bits (RTS toggels between hi and low byte) and he routed the signals to support 3 different types of lcds with straight ribbn cable so it is a very simple and easy to use board. The best of all is it only has 3 components on so it is cheap. Less than $12. Iwant to use the ks driver to and drive it serialy
Rudi Grobler
PostPosted: Fri Jul 16, 2004 18:37
Can you or your send post the stuff needed to build on of those pcbs ?
Tanxs,
||\//|ars \\/\\/alker
