| Noritake GU128x32-311 http://forum.lcdinfo.com/viewtopic.php?f=14&t=754 |
| Author: | fstrydom [ Mon Jul 19, 2004 17:56 ] |
| Post subject: | Noritake GU128x32-311 |
I picked up two of these displays on e-bay. Following the wiring diagram posted on this forum, I tried connecting the display this past weekend. Needless to say - unsuccessful! So I have a two part question - How do I make sure the display is not faulty. The documentation says to "hold T0 to low". What does this mean? Next, what should I expect as soon as I power on the PC or load the LCD info program, should I see backlight? |
| Author: | coorz [ Mon Jul 19, 2004 18:43 ] |
Backlight Make sure your VFD is powered and connected to LPT before you turn on your PC. Check the driver configuration in LCDInfo, and recheck your wiring a couple of times. You do need to 'make' some screens otherwise nothing will happen |
