It is currently Wed Jul 02, 2025 15:15
PostPosted: Thu Sep 16, 2004 15:31
Any chance on support for this display?
It's a SERIAL display.
Review @ http://www.bit-tech.net/review/120
Tech details @ http://forums.bit-tech.net/showthread.php?t=12398
Thanks in advance
PostPosted: Thu Sep 16, 2004 17:50
I have that display too, besides LCDC i believe it's also supported by LCDHype. Don't know if Henri has time to write a driver for it if he only has the data-sheet :wink:
PostPosted: Fri Sep 17, 2004 16:28
There are always chances but I'm not seeing it supported very soon unless I will somehow get that kind display for myself to work with.
EDIT:
I just sent email to Noritake about this. We'll see what they say (if I get a reply).
PostPosted: Tue Sep 21, 2004 16:43
The official spec/programming reference sheet is here (PDF format)
It's usually opened as a 19200/8/n/1 Serial connection (Though if you can get the delay timings right, you can open it @ 38400/8/n/1).
All the character movement references, graphic display references and the rest are all in there, as well as the timing needs.
I hope this helps you out some.
