| Noritake GU126x32F-K612A4 http://forum.lcdinfo.com/viewtopic.php?f=14&t=837 |
| Author: | Anaerin [ Thu Sep 16, 2004 15:31 ] |
| Post subject: | Noritake GU126x32F-K612A4 |
Any chance on support for this display? It's a SERIAL display. Review @ http://www.bit-tech.net/review/120 Tech details @ http://forums.bit-tech.net/showthread.php?t=12398 Thanks in advance |
| Author: | coorz [ Thu Sep 16, 2004 17:50 ] |
I have that display too, besides LCDC i believe it's also supported by LCDHype. Don't know if Henri has time to write a driver for it if he only has the data-sheet |
| Author: | Henri [ Fri Sep 17, 2004 16:28 ] |
There are always chances but I'm not seeing it supported very soon unless I will somehow get that kind display for myself to work with. EDIT: I just sent email to Noritake about this. We'll see what they say (if I get a reply). |
| Author: | Anaerin [ Tue Sep 21, 2004 16:43 ] |
The official spec/programming reference sheet is here (PDF format) It's usually opened as a 19200/8/n/1 Serial connection (Though if you can get the delay timings right, you can open it @ 38400/8/n/1). All the character movement references, graphic display references and the rest are all in there, as well as the timing needs. I hope this helps you out some. |
