It is currently Tue May 21, 2013 4:29
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Jun 12, 2004 14:47
To get a little feedback.... how is it to work with the designer...does it help to create screens ?
PostPosted: Sun Jun 13, 2004 23:48
Of course it helps. :D
PostPosted: Sun Jun 27, 2004 12:39
Great job Relampago, thanks :D
Just go on ;)
Just one thing, as already mentionned : absence of zoom on the preview is a real lake, especially in 1280x1024 or more :(
 Post subject: Problem with animation
PostPosted: Wed Sep 08, 2004 16:04
I can't add animation frames in the new screen designer . In the Animation-Edit section of the screen deisgner the only option i can use is save animation which does nothing if i try to view on my display. Is there a reason i can't use them yet,. are they not enabled in this version?
Is there another way i can animate bmp's on my vfd. if so can somebody please send me an example file.
Cheerz
 Post subject: Wow animation :D
PostPosted: Wed Sep 08, 2004 18:03
Ok, i went away and tried other stuff and i got my animation working,.
you can see here an example video of a running cat with sum random text in the background.
http://www.neutek.uk-ds.com/LCDinfo/cat3.avi
you can also download the xml file and bmp's here.
http://www.neutek.uk-ds.com/LCDinfo/cat.rar
Cheers
NeuTek
PostPosted: Mon Oct 11, 2004 0:50
Hello there!
Very nice programm and very helpful Relampago!! Of course zoom will make it much more easier! I also have a suggestion.
The exported file is a little messed up and the commands(?) are not easily clear and if you want to edit the file manually you must search alot within the text for the correct text string. OK ctrl+F is a good solution but it would be much more pretty if it was nice and clear with tabs and blank lines between the commands :)
gsmaster :)
PostPosted: Sun Dec 05, 2004 2:13
Like Neutek, I can't seem to add animations...
And I might be a bit of a newbie here... but I also can't work out how to add the plugin variables... Is there a brief manual, or help file to help me understand the designer better?
PostPosted: Sun Dec 05, 2004 2:16
It's a great tool BTW. :) Thanks. :)
PostPosted: Sat Dec 11, 2004 18:09
ok the pluginloading is hardcoded in this version... if you dont see your plugin (the plugin you want to use) int the right treeview there is now way to use this. If the plugin is there open up the treeview and simply drag&drop the variable...tata..
 Post subject: Me again..
PostPosted: Sat Feb 12, 2005 19:05
Relampago,
Don't suppose you feel like doing a bit more work on the designer? ;) Two things that would be great to see in the new and improved version...
Structured output of the screen file. So that it's easier to modify afterwards.
and...
Integration with the screens.xml, so that you can edit the screens file as well as the actual screens. Or even just a tick box on each screen that when ticked, makes sure the screen is either in, or gets added to the screens file.
PostPosted: Sat Mar 26, 2005 21:17
how can i see what it looks like whit out using the display
you can in lcdinfo 0.3
why not in lcdinfo 0.6 ??
Thomas
 Post subject: have problems
PostPosted: Sun Mar 27, 2005 20:21
hi
iv downloaded the prog and i have some problems :
1. How to do animations
When i click on the "Inset New Animation"
it is looking for a file "babe-10b.bmp" ????
2. Why is there no PreView ??
other wise keep up the good work GREAT PROGRAM
Thomas
.-={Hike or Die}=-.
PostPosted: Thu Apr 21, 2005 16:17
Hi guys,
sorry but i have no time for that software, i opened the sources somewhere in the forum. so if you find some one who want to improve this urgly software.... :roll:
PostPosted: Mon May 02, 2005 10:21
Error
Appliation has generated an exeption that could not be handled
Processid id = 0xd74, Thread id= 0x6a8(1704)
click ok ....
click cancel....
PostPosted: Mon May 02, 2005 12:54
It's beta, but it should work nonetheless to a certain extent. So make sure you have all the requirements to run it.
