| NEW DESIGNER !! http://forum.lcdinfo.com/viewtopic.php?f=16&t=600 |
Page 1 of 4 |
| Author: | Relampago [ Mon Apr 12, 2004 21:22 ] |
| Post subject: | NEW DESIGNER !! |
1.1.2 icons now also appear on http://www.hypertransport.de/designer/lcdinfoscreendesigner1.1.2.rar (( not needed with build 18 of LCDInfo anymore ) works only with : www.hypertransport.de/designer/lcdinfo.exe ) and .NET 1.1 http://www.microsoft.com/downloads/deta ... layLang=en Changelog: 1.1.2 - fixed bug: pluginimages disappeared after leave the dragarea ( thx for the report Vric ) 1.1.1 - icons for plugins added - icons also appear on loaded screens, so now you see where the vars come from 1.1 - Size of previewscreen now depends on configuration done in lcdinfo under driver - loading of seperate screens is posibble - added option to stop/restart lcdinfo..so its easier to review a saved screen on the lcd - size of pluginimages is 1:1 + name Fixes: - removed saving bug - removed display bug - removed bug where the position and fieldsize were calculated wrong ( text disappears from preview ) - removed drag&drop bug ( draghandles still flashes for short time) - performance on startup increased - removed loading bug (specific screen) thx@henri |
| Author: | Henri [ Mon Apr 12, 2004 22:28 ] |
Looks good |
| Author: | Relampago [ Tue Apr 20, 2004 0:00 ] |
a little update: link: *removed* |
| Author: | coorz [ Tue Apr 20, 2004 17:34 ] |
Wow that's one FAST PC you got there /yes ICQ suxx |
| Author: | Relampago [ Fri Apr 23, 2004 7:34 ] |
why fast pc ? yes q icq...but for some reason i use it |
| Author: | Relampago [ Sun Apr 25, 2004 22:11 ] |
new demonstration video : summary of some weekendwork www.hypertransport.de/designer/animation.rar |
| Author: | Henri [ Tue Apr 27, 2004 10:07 ] |
Looks better after every update |
| Author: | Schijf [ Tue Apr 27, 2004 10:32 ] |
Now that looks very sweet *shrug* you wouldn't have time to make a version for LiQuiD-MP3 (with XML configs) would you.... *whistles innocently* |
| Author: | Relampago [ Fri Apr 30, 2004 22:59 ] |
next update please ignore some drawing bugs...removed right now www.hypertransport.de/designer/someupdate.rar |
| Author: | Relampago [ Thu May 06, 2004 23:06 ] |
another update..this time a bit funny because i found a bug while capturing The pluginvariables are loaded directly from lcdinfo...if you look close, there is also a bug www.hypertransport.de/designer/demo+crash.rar TODO: save aniomation in own xml load animations via drag&drop |
| Author: | coorz [ Fri May 07, 2004 10:39 ] |
Relampago wrote: why fast pc ?
Probably your capturing software, everything moves so damn fast Any chance of us having a go at your beta screen designer |
| Author: | Relampago [ Sat May 08, 2004 21:53 ] |
FIRST RELEASE: www.hypertransport.de/designer/Release.rar You need the .NET Framework...this software is full C# a demovideo is following later.... Some hints: - copy both files in your directory where lcdinfo.exe is located - drag and drop pluginvariables from the left tree to the screen - drag&drop saved animations - drag&drop bitmaps from your explorer TODO: -lcdinfo can not be run at same time - with "load existing screens" you select your lcddirectory e.g. 320x240 or what ever - only 320x240 lcds are supported, ok thats simple so for small lcds simply edit in the upperleft corner - bug in treeview of lcdinfo vars - you need a newer build of lcdinfo where a path bug is removed - screen.xml editing issnt implemented - pluginvars can only be setted one time on a screen |
| Author: | coorz [ Sat May 08, 2004 22:08 ] |
Vielen dank Relampago, i'll have a go at it next week. /P.S. see you June 15th Portugal |
| Author: | Relampago [ Mon May 10, 2004 9:16 ] |
| Post subject: | .NET 1.1 Framework |
Here the dld link for .NET 1.1 http://www.microsoft.com/downloads/deta ... layLang=en Please post every bug |
| Author: | Relampago [ Mon May 10, 2004 22:45 ] |
| Post subject: | new version .. have fun |
alpha 1.1 www.hypertransport.de/designer/lcdinfos ... ner1.1.rar works only with : www.hypertransport.de/designer/lcdinfo.exe Changelog: - Size of previewscreen now depends on configuration done in lcdinfo under driver - loading of seperate screens is posibble - added option to stop/restart lcdinfo..so its easier to review a saved screen on the lcd - size of pluginimages is 1:1 + name Fixes: - removed saving bug - removed display bug - removed bug where the position and fieldsize were calculated wrong ( text disappears from preview ) - removed drag&drop bug ( draghandles still flashes for short time) - performance on startup increased - removed loading bug (specific screen) thx@henri |
| Page 1 of 4 | All times are UTC + 2 hours |
