It is currently Sat Feb 27, 2021 21:43
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 23, 2005 23:45
The SED board i'm using has a 10Mhz XTAL. If that's what you mean, i assume your CF has the same.
Your wiring scheme might work with LCDinfo as it has a configurable SED1335 driver dialog.
PostPosted: Sun Apr 24, 2005 0:11
One more quick question about LCDInfo installation. All I need is the DriverLINX driver found in port95nt.exe along with the program itself correct? This port95nt.exe is the same driver that Liquid-MP3 uses correct?
PostPosted: Sun Apr 24, 2005 0:27
No need for those port drivers. LCDinfo uses WINIO which is automatically loaded when using LCDinfo.
PostPosted: Fri Sep 02, 2005 3:33
coorz how did your get your spectrum analyzer to do bars???
PostPosted: Fri Sep 02, 2005 4:15
check the log.txt in the lcdinfo root folder, it has all the possible varaibles. I beleive the bars are called spectrumbar2, can't check as i'm on holidays now :D
PostPosted: Fri Sep 02, 2005 11:59
hey if got a toshiba laptop lcd very similar to this.. with blue el back light... do you reakon i could hook it play and pray???
it would be so mean to have an LCD that size
i also have this one out of a toshiba laptop which still goes.... its a classical 240X128 i think... big wide screen thing
they are a T7778A cant find any info on them.... but the same pinout outs as T6XXX im just gunna use the laptop to power it cause i cant be botherd doing dc/dc if it doesnt work and see if i bit rape it :P 8O
PostPosted: Sat Sep 03, 2005 0:43
would seem i have 2 accounts and didnt even realize lol :P hahahaha now which one to use...... :roll:
