It is currently Sun Nov 08, 2026 6:27
 Post subject: Screens problem...
PostPosted: Sat Jan 15, 2005 16:25
Hey, having some issues with some screens atm, If i've set a bmp for a screen, when it changes the image is still displayed over the top of whatevers dislpayed on the screen... Any ideas on solving this?
I've tried using a screen which is just a blank image, but that doesnt seem to work, and its a bit of a hack!
Thanks :D
PostPosted: Sat Jan 15, 2005 18:30
You need to make a background bitmap for every screen you make.
PostPosted: Sat Jan 15, 2005 18:54
I've got some all filled in bmps created... but they dont seem to wanna "display"...
Trying them on their own produces the same, even adding a few pixels not filled in, still dont seem to wanna display... :oops: :oops:
PostPosted: Sat Jan 15, 2005 22:28
Recheck your paths/filenames, bitmap has to be 1bit B/W.
PostPosted: Sun Jan 16, 2005 13:25
Ok thanks :)
I've been editing the current bmp's i've been given that work fine when they arent a solid block, but as soon as the white is removed they dont work :S
PostPosted: Sun Jan 16, 2005 23:56
Are you editing in photoshop or paint? In photoshop u convert to grayscale to edit the image then convert back to bitmap and they work.
Here is a clear back image: http://www.redhotfilament.net/lcdinfo/clearback.rar
PostPosted: Tue Jan 18, 2005 12:36
Works like a treat cheers :D strangely though it appears to be the same file i've got a couple of copies of which refuse to work :S
PostPosted: Tue Jan 18, 2005 16:57
Just make sure its a 1 bit b/w thats probably the difference, this for me for a little bit also
PostPosted: Thu Jan 20, 2005 1:31
If you want you can email me the working and non working bitmaps and maybe I could have a look with a hex editor and try to see why it doesn't work.
PostPosted: Sun Jan 23, 2005 21:19
Ok, mail sent :)
