It is currently Fri Mar 29, 2024 13:47
PostPosted: Sat Nov 13, 2004 17:52
when I open the project..
lcdinfo.dsw
with VC++ 6
I get the following errors:
displayitems.cpp
lcd.cpp
lcdinfo.cpp
c:\documents and settings\stoffe\mina dokument\lcd\lcd\lcdinfo source\org\lcdinfo\lcdinfo.cpp(433) : error C2065: 'NOTIFYICONDATA_V1_SIZE' : undeclared identifier
plugin.cpp
registry.cpp
c:\documents and settings\stoffe\mina dokument\lcd\lcd\lcdinfo source\org\lcdinfo\registry.cpp(68) : error C2065: 'REG_QWORD' : undeclared identifier
screen.cpp
screenfiles.cpp
stringitem.cpp
anyone that had the same problem? Do i need something more to build the project?
Kristoffer
PostPosted: Sun Nov 14, 2004 19:32
There shouldn't be anything special needed. Have you installed any service packs for VC++ ? I think I'm using SP5. I also have the Platform SDK installed if that makes any difference.
Which OS are you using ?
This seems to suggest that REG_QWORD is a 64-bit number in case you might want to try making your own define for it:
http://msdn.microsoft.com/library/en-us ... _types.asp
http://msdn.microsoft.com/library/en-us ... ondata.asp
