| USB480-Player http://forum.lcdinfo.com/viewtopic.php?f=19&t=2537 |
| Author: | sos [ Wed Nov 05, 2008 17:34 ] |
| Post subject: | USB480-Player |
Hello Here is my Player now in Fullcolor. Have Fun. Download here
| Author: | Henri [ Thu Nov 06, 2008 13:00 ] |
Happy to see this transformation to color for the player |
| Author: | sos [ Thu Nov 27, 2008 22:57 ] |
Here is a Version to control the Player over Touchscreen. Download here |
| Author: | sos [ Thu Dec 04, 2008 11:12 ] |
"Screenshotfunktion" added and some little modifikations.
| Author: | Michael [ Fri Dec 05, 2008 10:49 ] |
sos wrote:
Hi, While the output itself is quite nice the touch interface doesn't seen functional from here. Ie, there is no response from anywhere on the planel. Nice effects |
| Author: | sos [ Fri Dec 05, 2008 12:46 ] |
Michael wrote: Hi,
While the output itself is quite nice the touch interface doesn't seen functional from here. Ie, there is no response from anywhere on the planel. Nice effects Damn,the area was outside of the screen Fixed and works again. |
| Author: | Michael [ Fri Dec 05, 2008 13:50 ] |
Is now working. Is this programmed for a stylus or finger touch? I'm finding the touch sensitivity of this program to be abit erratic with a stylus but more consistant with a finger. |
| Author: | sos [ Fri Dec 05, 2008 17:44 ] |
i use a Timer to get results from touchpanel Code: SetTimer_(WindowID(Window_0),3,600,@touchinfo()) this means ths touch works with "1.6 fps" The 600 ms is experimental and maybe a little bit slow. Here is the code to check the Buttonpanel Code: If tpx>0 And tpy>0 And DisplayProperties\Width-tpx>xwin-50
Select DisplayProperties\Height-tpy Case 10 To 50 CallEventFunction(Window, Event, ButtonImage_0, Type) Case 60 To 100 CallEventFunction(Window, Event, ButtonImage_1, Type) Case 110 To 150 CallEventFunction(Window, Event, ButtonImage_2, Type) Case 160 To 200 CallEventFunction(Window, Event, ButtonImage_3, Type) Case 210 To 250 CallEventFunction(Window, Event, ButtonImage_4, Type) EndSelect EndIf I make no distinction between pen and finger. Edit timer changed,its more "sensitive" now |
| Author: | Henri [ Fri Dec 05, 2008 18:33 ] |
More eye candy Making accurate touch interfaces should become easier with the upcoming new improved filtering and calibration. |
| Author: | sos [ Sat Dec 06, 2008 13:50 ] |
I have rewritten my touchcontrol as seperate Thread now. The time between 2 USBD480_GetTouchPosition is now 100 ms,if the time is lower i get wrong results some times. |
| Author: | One~Zero [ Sun Jan 11, 2009 0:32 ] |
The audio playback when using this is very scratchy....am I the only one with this problem? |
| Author: | Henri [ Mon Jan 12, 2009 13:37 ] |
One~Zero wrote: The audio playback when using this is very scratchy....am I the only one with this problem?
I haven't noticed but I'll try listening more carefully next time. Have you tried adjusting the volume and other settings? |
| Author: | sos [ Mon Jan 12, 2009 21:18 ] |
sos wrote: Archive is is updatet,newest fmodex-version and some modifikations One~Zero wrote: The audio playback when using this is very scratchy....am I the only one with this problem?
Check your Hardware and Driver. I use onbord Soundmax HD and no Problems here. |
