It is currently Sun Nov 08, 2026 19:20
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue Feb 18, 2003 13:48
DarkElf wrote:
the bar samtech proposed shouldn't be implemented as graphic, it will be kicker to calculate it and to put 3 sprites: one at start, one a end and one position. It would permit to make them of the size we want.
If you have some algorithms for this / would like to work on one let me know of your ideas. Any help would definately speed up the process. :D
PostPosted: Tue Feb 18, 2003 20:55
XNDR° wrote:
GoldServe wrote:
A little too expensive....shipping from states is more than enough...shipping europe is even more! ={
The company is Dutch, I'm running it together with someone else...
Where do you live?
Well , im from portugal i i would also like very much of one of those bauties !!!! in blue stile , but still thnk them as a bit expensive for the portuguese pocket's :( but in case ill oder one , how would it be the sipping cost for Portugal , Lisbon ??
Has for the grafical bars spite idea , you should be right about that (i think ) , bu i dont' realy know much abou programing :(
Samtech
XP 2000+
A7N8X Dlx
256 Mb DDR PC3200 OCZ
GF 4 Ti 4200 128 DDR
180 Gb
Studio PCTV Pro
PostPosted: Wed Feb 19, 2003 15:04
Well, I have done this progress bar in full line command (no bmp):
the first one:
_____________
|###________|
the second one:
Here is is alpha num, but its continous pixels in my funcs.
void Graphic_LCD::Graphbar1(int x, int yb, int value , int lenth )
   int i,limit,y,cs;
   y = yb>>3;                                          // y divided by 8
   i = x;
   limit = x + value;                                    // calc limit between full & empty
   // **** [ part ****
//_ This part of code is a quicker way to configure the right chip where we need
   if ((x) < 64) {
      cs = LCD_CS1;
      SendLCDCommand(DISPLAY_COLUMN_SET | (x&63), LCD_CS1);
      SendLCDCommand(DISPLAY_PAGE_SET | y, LCD_CS1);}
   else {
      cs = LCD_CS2;
      SendLCDCommand(DISPLAY_COLUMN_SET | ((x-64)&63), LCD_CS2);
      SendLCDCommand(DISPLAY_PAGE_SET | y, LCD_CS2);}
//_|
   LCDInfo->DLPortIO1->PortW[CONTROL] = cs;               // cs, rs=1, e=1
   Delay();
   LCDInfo->DLPortIO1->PortW[DATA] = 0x7C;                  // send 0111 1100 <=> |
   Delay();
   LCDInfo->DLPortIO1->PortW[CONTROL] = LCD_ENABLE | cs;      // cs, rs=1, e=0
   Delay();
   // **** first part / full part ****
   while (++i<=limit) {
      if (i < 64) {
         cs = LCD_CS1;
         SendLCDCommand(DISPLAY_COLUMN_SET | (i&63), LCD_CS1);
      else {
         cs = LCD_CS2;
         SendLCDCommand(DISPLAY_COLUMN_SET | ((i-64)&63), LCD_CS2);
      Delay();
      Delay();
      Delay();
   // **** second part / empty part ****
   while (++i<=(lenth-1))
      if (i < 64) {
         cs = LCD_CS1;
      else {
         cs = LCD_CS2;
      Delay();
      LCDInfo->DLPortIO1->PortW[DATA] = 0x44;                  // send 0100 0100 <=> :
      Delay();
      Delay();
   // **** ] part ****
   if ((x+lenth) < 64) {
      cs = LCD_CS1;
      SendLCDCommand(DISPLAY_COLUMN_SET | ((x+lenth)&63), LCD_CS1);
   else {
      cs = LCD_CS2;
      SendLCDCommand(DISPLAY_COLUMN_SET | ((x+lenth-64)&63), LCD_CS2);
   Delay();
   Delay();
   Delay();
void Graphic_LCD::Graphbar2(int x, int yb, int value , int lenth )
   int i,y,cs;
   i = x;
   // **** [ part ****
   if ((x) < 64) {
      cs = LCD_CS1;
   else {
      cs = LCD_CS2;
//_|
   Delay();
   Delay();
   Delay();
   // **** line part ****
      if (i < 64) {
         cs = LCD_CS1;
      else {
         cs = LCD_CS2;
      Delay();
      if ( (i==(value-1)) || (i==(value+1)) )
         LCDInfo->DLPortIO1->PortW[DATA] = 0x40;               // send 0100 0000 <=> _\/_
      if (i==value)
         LCDInfo->DLPortIO1->PortW[DATA] = 0x70;               // send 0111 0000 <=> _|_
      else
         LCDInfo->DLPortIO1->PortW[DATA] = 0x40;               // send 0001 0000 <=> ___
      Delay();
      Delay();
   // **** ] part ****
      cs = LCD_CS1;
   else {
      cs = LCD_CS2;
   Delay();
   Delay();
   Delay();
It is optimized for speed &
It could have some bugs... (because I have done this yesterday night while watching the TV QI-Test program)
PostPosted: Wed Feb 19, 2003 15:46
I'll have a look at the code :D
PostPosted: Thu Feb 20, 2003 4:26
Well , what can i say !!
Great Work , now let's hope it works ;-)
SAmtech
XP 2000+
A7N8X Dlx
180 Gb
Studio PCTV Pro
PostPosted: Thu Feb 20, 2003 12:10
There is some errors...
after the while () I have forgotten some {...
I just wrote my first WMP plugin, it work fine for a two hour work :D
PostPosted: Thu Feb 20, 2003 13:26
Sounds good... :)
