It is currently Mon Nov 09, 2026 22:32
PostPosted: Fri Jan 24, 2003 16:20
english:
I have a problem ..!!
I will use more NT counter use ,but one will going ..
If I more than a counter use will want only the status of the first indicated or with all the same appraise.
Here can see
I have already several possibilities tried however no success
sorry for my english ...
German:
Ich habe ein Problem mit mehreren NT Counter .. egal was ich einstelle ..ich bekomme immer den Wert vom ersten Counter .bei den anderen countern angezeigt ,habe schon mehrere möglichkeiten getestet aber ohne Erfolg ..
Info: 128x128 Display with T6963 controler
LCDinfo v. 0.3.2.
PostPosted: Fri Jan 24, 2003 19:35
I'll have to admit that I don't know what the problem is and you are the first one I've heard reporting this. Maybe the problem is in the precision and multiplier handling in LCDInfo as everything seems to be fine in the config program. Have you tried experimenting with the precision and multiplier values ?
If anyone else is experiencing this please let me know.
I'll have a look at this later...
PostPosted: Fri Jan 24, 2003 20:36
I have yes, that. Changing does itself there also nothing. . An Infomation what Multiplier and Precision cause should would be perhaps helpful.
PostPosted: Fri Jan 24, 2003 21:46
heya postguru :)
maybe you better start from scratch. delete all your data that is in lcdperf.ini and put this into it:
[pdh_proztime]
name=\Prozessor(_Total)\Prozessorzeit (%)
multiplier=1
precision=4
[pdh_diskread]
name=\System\Bytes gelesen/s
multiplier=0,0009765625
precision=4
the variable names for the screens are $pdh_proztime$ and $pdh_diskread$
hth
Hase
hi postguru,
ich glaube es ist am besten du löschst nochmal die ganze lcdperf.ini und gibst nur die paar zeilen rein, die ich oben gepostet hab. die richtigen variablennamen hast du eh schon verwendet, ev. hilfts ja was.
ciao
Hase
PostPosted: Sat Jan 25, 2003 1:40
Thx
Danke ...
