| True type not rendering on the virtual display http://forum.lcdinfo.com/viewtopic.php?f=5&t=106 |
| Author: | linear [ Fri Jan 24, 2003 21:24 ] |
| Post subject: | True type not rendering on the virtual display |
LCDInfo 0.3.2 Win2k pro SP3 LCD output disabled for the moment I create a screen with truetype font objects in it, and they do not show up on the virtual display. Quote: [Info]
Description=Linear's batch of 128x64 screens [Font0] Name=Verdana Size=10 CutTop= CutLeft= Invert=1 [Screen0] Enable=1 Interval=5000 Bitmap=screens\linear\mobo-128x64.bmp Graphic0=text(60,25,0,"Hello, world")
| Author: | Hase [ Fri Jan 24, 2003 21:35 ] |
[Font0] Name=Verdana Size=8 CutTop=1 CutLeft=1 Invert=0 [Screen1] Enable=1 Interval=5000 Bitmap=screens\128x128_t6963c_images\system.bmp Icon0= Icon1= Icon2= Icon3= Icon4= Icon5= Icon6= Icon7= Icon8= Icon9= Line0="" Line1="" Line2="" Line3="" Line4=" $computername$" Line5="" Line6="" Line7=" AMD XP1700+ @ $mbmmhz$" Line8="" Line9="" Line10=" MSI GF4 Ti4200" Line11="" Line12="" Line13=" Windows XP SP1" Line14="" Line15="" Graphic0=text(46,113,0,$time$) works fine for me ... |
| Author: | linear [ Fri Jan 24, 2003 21:47 ] |
I figured it may be related to the LCD being disabled, does it work on the virtual if you disable the LCD output? |
| Author: | Henri [ Fri Jan 24, 2003 21:47 ] |
Now that I think of this it might be that the truetype font support isn't even implemented in the "LCD output disabled" mode. Just use the KS0108 setting instead and it should work fine. With the KS0108 setting it writes to the parallel port though but this shouldn't be a problem ? |
| Author: | linear [ Fri Jan 24, 2003 21:49 ] |
I had tried the Toshiba setting and it threw major errors, so I was too chicken to try the other one...
| Author: | Hase [ Fri Jan 24, 2003 21:51 ] |
Henri wrote: Now that I think of this it might be that the truetype font support isn't even implemented in the "LCD output disabled" mode.
