It is currently Mon Nov 09, 2026 21:26
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: EAccessViolation
PostPosted: Fri Jan 31, 2003 18:58
After installing 0.3.2_nt i'm getting an exception with the message: "EAccess Violation"...
What does this mean, and how can i fix it?
Except of this little problem: It's a nice prog!
PostPosted: Fri Jan 31, 2003 20:26
It means that LCDInfo tried to do something windows didn't like ;)
How often are you getting this ? Right when you start LCDInfo or once in a while ?
I'm not sure what's causing it but this might already be fixed in 0.4.
One thing causing it might be the pop3 check but this is just guessing.
PostPosted: Fri Jan 31, 2003 20:50
i get this exception everytime i try to start the programm while the checkbox "enable nt performance counters (nt only)" is activated. after deactiveting the checkbox the prog runs, but without the performance counters.
i also tried to change my registry (it was discribed in another thread), but with no effect.
btw: i use win2k with sp3...
where can i download 0.4? i couldn't find it yet...
PostPosted: Fri Jan 31, 2003 21:01
You can't find 0.4 anywhere as it isn't available yet. ;)
You could post your performance counter ini file here if that would bring up any ideas.
PostPosted: Fri Jan 31, 2003 21:26
my lcdperf.ini:
[pdh_recpros]
name=\Netzwerkschnittstelle(NDIS 5.0 driver)\Empfangene Bytes/s
multiplier=1
precision=4
[pdh_cpuprozc]
name=\System\Prozesse
multiplier=1
precision=4
btw: i have the same problems with 0.4... :?
PostPosted: Fri Jan 31, 2003 21:51
Ok, have you tried with only one counter in the ini like cpu% for example ?
I think the counter code is in need of some rewriting so I'll have a look at it in some point.
PostPosted: Sat Feb 01, 2003 18:41
i tried it, but it was still the same...
