| Anyone interested in making plugins ? http://forum.lcdinfo.com/viewtopic.php?f=5&t=131 |
| Author: | Henri [ Mon Feb 10, 2003 0:40 ] |
| Post subject: | Anyone interested in making plugins ? |
Is there anyone who would be interested in making plugins for LCDInfo ? If so what language would you use ? I'm asking this because I'm currently working on the plugin interface for the new LCDInfo version and I was thinking about portability between different programming languages. Basic use for plugins would of course be the data plugins but I thought that it might be also possible to add some callbacks to increase functionality. |
| Author: | Plasma [ Thu Feb 13, 2003 23:55 ] |
As you know, I'm very interested. Either C++ or just plain C. You also know what plugins I'd make. |
| Author: | Henri [ Sat Feb 15, 2003 11:57 ] |
Ok. When I get a little further I'll make some kind example project of a plugin. |
| Author: | DarkElf [ Tue Feb 18, 2003 13:01 ] |
I am also interested, it will permit me not to develop my own lcd app (what i'm actually doing) & lcd info will be better than power lcd Good plugins could be done but lcd info should change a little (a big I think because you can't do it actually - I think): instead of always replace lcd data with new one you should make a newdata= actualdata | data function. I have got some ideas and one of the first that need to be done is a progress bar (have you ever seen jalcd ? try to look at it, it is a good program for alphanumeric displays) Look also to my topic in the hardware section, the one about the ks0108b |
| Author: | Henri [ Tue Feb 18, 2003 14:00 ] |
DarkElf wrote: Good plugins could be done but lcd info should change a little (a big I think because you can't do it actually - I think): instead of always replace lcd data with new one you should make a newdata= actualdata | data function. You mean this for graphics or text ? If I understood that right this is pretty much how it's done in the new graphics code. If you have read the old source available you can pretty much forget how things are done there as I'm completely rewriting LCDInfo currently. So just let me know what you would need and I'll see if I could implement that. If you would like to know more of the inner workings of the new version just email me. I hope that the new version will allow to better take advantage of the graphical lcd's/VFD's possibilities. edit: let's not forget the VFD's here Quote: I have got some ideas and one of the first that need to be done is a progress bar (have you ever seen jalcd ? try to look at it, it is a good program for alphanumeric displays)
In the 0.3.2 version there is already a winamp progress bar as an undocumented feature. edit: The winamp progress bar for 0.3.2: Graphic0=winamp_progbar(10,55,5,100) winamp_progbar(xposition,yposition,height,width) |
| Author: | DarkElf [ Wed Feb 19, 2003 14:40 ] |
arg... thank for the winamp progress bar... So you want to know what I want? I have done some nice things under TI 92+/TI89 68K ASM, I was used to use virtual screens to put my graphics & my texts It was looking like this: Init of virtual screen Infiny Loop | Erase virtual screen | Put what i want on it | Copy virtual to real So I need a virtual screen (really love them) What you said Globally what I need: Get what there is were I want Put what I want where I want (pixel position). I will mainly dev plugins for WMP, because somebody else will make them for winamp and also because I don't really like winamp. |
| Author: | Henri [ Wed Feb 19, 2003 15:45 ] |
The graphics in the next version are based on frame buffer so you might like it. I guess the progressbars could be also translated to the new version. WMP plugin would be great and I've already begun working on a winamp plugin a while ago. If you want to have a peek at the current code I think that could be arranged. You might have a chance to influence how it's implemented. |
| Author: | Relampago [ Wed Feb 19, 2003 23:24 ] |
| Post subject: | yes iam |
im very interested in programming plugins c/c++ |
| Author: | inzo [ Thu Feb 20, 2003 6:53 ] |
Darkelf Quote: So I need a virtual screen (really love them)
I think a virtual screen would be a good addition, that way when you can get to your lcd screen you canstill test your code. |
| Author: | inzo [ Thu Feb 20, 2003 7:02 ] |
clarification: I mean a virtual screen as in a lcd screen emulator app to run code on b4 you try it on the actual lcd and it doesnt work. |
| Author: | Henri [ Thu Feb 20, 2003 10:10 ] |
inzo wrote: clarification:
I mean a virtual screen as in a lcd screen emulator app to run code on b4 you try it on the actual lcd and it doesnt work. At the moment there is a virtual screen that uses the same interface as the actual drivers. So if you wan't to use different controller/virtual screen, you can just replace the driver DLL with what you want. |
| Author: | DarkElf [ Thu Feb 20, 2003 14:31 ] |
/!\ When I talk about virtual screen, I mean a buffer where you temp. put data before the screen is sent to the lcd it is fully different to a lcd simulator! I just finished my first WMP plugin, this is a scope plugin. Ok... nothing fabulous... BUT the scope is on the LCD (it worl only for ks0108b, because my lcd is a ks0108b - you need DLPortIO installed) My plugin should work on WindowsMediaPlayer 7 & upper, but only tried under the WMP9 & Win XP here to find it: http://www.geocities.com/martien_1998/wmplcd.zip try it & let me know what you think about it... If you let me look at some code, it will help me a little for my functions/plugins... Henri: Have you any idea on how to communicate between the plugin & lcdinfo? WMP plugins must be DLL that media player run himself so to communicate you must put a shared memory (like MBM). An other solution is to implement a solution like jaLCD: TCP-IP interconnection. I don't konw many things about the first one. And i don't really like the second one |
| Author: | Henri [ Thu Feb 20, 2003 15:10 ] |
DarkElf wrote: /!\ When I talk about virtual screen, I mean a buffer where you temp. put data before the screen is sent to the lcd it is fully different to a lcd simulator! LCDInfo has both Quote: I just finished my first WMP plugin, this is a scope plugin. try it & let me know what you think about it... Great, I'll try that later today when I get access to KS0108 LCD. Quote: If you let me look at some code, it will help me a little for my functions/plugins... I'll email you later today... Quote: Henri: Have you any idea on how to communicate between the plugin & lcdinfo?
I guess you need to use something like the shared memory you mentioned to share the data between the WMP plugin and the LCDInfo WMP plugin. That's what I've done in the winamp plugin. For some code snippets of what I've used have a look here: http://www.skippari.net/phpBB2/viewtopic.php?t=147 |
| Author: | DarkElf [ Thu Feb 20, 2003 15:31 ] |
Just read it. It look like the MBM shared memory code. I will look at this better tonight I will also give a look to msdn. For information I use Visual C++ 6, I hope there is no problems with shared mem between microsoft c++ & borland c++ |
| Author: | Henri [ Thu Feb 20, 2003 17:03 ] |
The code is pretty much straight from this MSDN example: http://msdn.microsoft.com/library/defau ... memory.asp I don't think there should be problems as I did the winamp plugin with visual c++ and the app that reads the shared memory with c++ builder and didn't notice any problems. As long as you don't use any compiler specific data types everything should be ok. |
