| 128x128 T6963C doesn't show anything with 0.3.2 http://forum.lcdinfo.com/viewtopic.php?f=5&t=141 |
| Author: | Guest [ Fri Feb 14, 2003 21:16 ] |
| Post subject: | 128x128 T6963C doesn't show anything with 0.3.2 |
Hi The new versiond doesnt work with 128x128 Displays with t6963c controller can u fix it please |
| Author: | Hase [ Fri Feb 14, 2003 23:26 ] |
hmm, can you specify that 'new version' you're talking about a bit more specifically? i'm running 0.3.2 and some of the pre 0.4.nn versions, and they all run fine with my 128x128 t6963c display |
| Author: | Henri [ Sat Feb 15, 2003 11:46 ] |
Knowing what the "new version" is would definately help and also what kind problems you are having ? |
| Author: | Guest [ Sun Feb 16, 2003 3:07 ] |
I mean 0.3.2. The Display doesnt show anything. In version 0.3.1. is everything fine |
| Author: | Henri [ Sun Feb 16, 2003 12:43 ] |
Was the 0.3.1 downloaded here or is it the Ayreon's version ? Do you have the wiring setup correctly in the configuration ? If you used the Ayreon's wiring diagram you need to use the tweakers.net/powerlcd wiring. |
