It is currently Sun Nov 08, 2026 19:35
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: Problems using LCDInfo
PostPosted: Sun Feb 16, 2003 0:57
Hello @ All,
first of all sorry for my bad englisch.
I have some problems to setup LCDInfo correctly. I´m using WinXP Prof. and a 128 * 64 Pixel LCD with a KS0108.
How must be the settings to display the voltage or CPU Mhz for example ?
Thanks,
Anana
PostPosted: Sun Feb 16, 2003 12:49
For the voltages and cpu mhz you need to have motherboard monitor running. You can get it here: http://mbm.livewiredev.com/
Or if you are looking how to edit the screens here is some explanation: http://www.skippari.net/phpBB2/viewtopic.php?t=57
Or did you have some other problems ?
PostPosted: Mon Feb 17, 2003 18:16
Thank you,
now it work´s fine. But now i have a other problem:
I have setup 2 Mail account´s. LCD-Info makes every time it check´s the acounts a error. A msgbox pop´s up with no text in it.
Or i get a cryptic accessviolation message !
Has anybody else this problem ? Is it a known bug ?
Bye,
ANANA
PostPosted: Mon Feb 17, 2003 20:08
LCDInfo probably isn't able to do the mailcheck correctly and gives this strange error. I think it could be called a known bug, although I've never experienced it myself.
PostPosted: Tue Feb 18, 2003 18:54
Thank you ! I have another question: The Updateintervall for the pop3 check is seconds or millseconds ?
Thx
Anana
PostPosted: Tue Feb 18, 2003 19:55
It's milliseconds so you can carefully adjust your updates :lol:
Maybe it should be changed to seconds.
PostPosted: Tue Feb 18, 2003 20:13
8O I´ve found the error ! *hehe* :D LCDInfo checked my E-Mailaccounts evers 600 milliseconds ... Now i changed the interval to 600000 ms and it work´s very well !!!
PS: Can you setup a threat at your forum for german users of LCDInfo ? (as you can see, my english is fu**ing bad ...)
Thx
Anana
PostPosted: Tue Feb 18, 2003 20:43
I think your english is much better than my german :)
If I made a german thread I wouldn't be able to read the posts or answer anything :cry:
