| Problems using LCDInfo http://forum.lcdinfo.com/viewtopic.php?f=5&t=143 |
| Author: | Anana [ Sun Feb 16, 2003 0:57 ] |
| Post subject: | Problems using LCDInfo |
Hello @ All, first of all sorry for my bad englisch. I have some problems to setup LCDInfo correctly. I´m using WinXP Prof. and a 128 * 64 Pixel LCD with a KS0108. How must be the settings to display the voltage or CPU Mhz for example ? Thanks, Anana |
| Author: | Henri [ Sun Feb 16, 2003 12:49 ] |
For the voltages and cpu mhz you need to have motherboard monitor running. You can get it here: http://mbm.livewiredev.com/ Or if you are looking how to edit the screens here is some explanation: http://www.skippari.net/phpBB2/viewtopic.php?t=57 Or did you have some other problems ? |
| Author: | Anana [ Mon Feb 17, 2003 18:16 ] |
Henri wrote: For the voltages and cpu mhz you need to have motherboard monitor running. You can get it here: http://mbm.livewiredev.com/
Or if you are looking how to edit the screens here is some explanation: http://www.skippari.net/phpBB2/viewtopic.php?t=57 Or did you have some other problems ? Thank you, now it work´s fine. But now i have a other problem: I have setup 2 Mail account´s. LCD-Info makes every time it check´s the acounts a error. A msgbox pop´s up with no text in it. Or i get a cryptic accessviolation message ! Has anybody else this problem ? Is it a known bug ? Bye, ANANA |
| Author: | Henri [ Mon Feb 17, 2003 20:08 ] |
Anana wrote: I have setup 2 Mail account´s. LCD-Info makes every time it check´s the acounts a error. A msgbox pop´s up with no text in it.
Or i get a cryptic accessviolation message ! LCDInfo probably isn't able to do the mailcheck correctly and gives this strange error. I think it could be called a known bug, although I've never experienced it myself. |
| Author: | Guest [ Tue Feb 18, 2003 18:54 ] |
Henri wrote: Anana wrote: I have setup 2 Mail account´s. LCD-Info makes every time it check´s the acounts a error. A msgbox pop´s up with no text in it. Or i get a cryptic accessviolation message ! LCDInfo probably isn't able to do the mailcheck correctly and gives this strange error. I think it could be called a known bug, although I've never experienced it myself. Thank you ! I have another question: The Updateintervall for the pop3 check is seconds or millseconds ? Thx Anana |
| Author: | Henri [ Tue Feb 18, 2003 19:55 ] |
Anonymous wrote: Thank you ! I have another question: The Updateintervall for the pop3 check is seconds or millseconds ?
It's milliseconds so you can carefully adjust your updates Maybe it should be changed to seconds. |
| Author: | Guest [ Tue Feb 18, 2003 20:13 ] |
Henri wrote: Anonymous wrote: Thank you ! I have another question: The Updateintervall for the pop3 check is seconds or millseconds ? It's milliseconds so you can carefully adjust your updates Maybe it should be changed to seconds. PS: Can you setup a threat at your forum for german users of LCDInfo ? (as you can see, my english is fu**ing bad ...) Thx Anana |
| Author: | Henri [ Tue Feb 18, 2003 20:43 ] |
Anonymous wrote: PS: Can you setup a threat at your forum for german users of LCDInfo ? (as you can see, my english is fu**ing bad ...)
I think your english is much better than my german If I made a german thread I wouldn't be able to read the posts or answer anything |
