It is currently Sun Oct 18, 2026 0:47
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Wed Feb 26, 2003 18:37
The wiring is ok (it works with liquidmp3) but with lcd info I get the left part on the right and vice versa. Any solutions for this?
PostPosted: Wed Feb 26, 2003 18:46
with liquid mp3 you can choose which pin is where. So it's greatly possible that you may have inverted CS1 & CS2 pins.
It's the only solution because I have got a ks0108b and it work fine and also because i know how lcd_info control the ks0108b and it can't invert left & right
PostPosted: Wed Feb 26, 2003 18:50
thx, I'll switch them and see if this works
PostPosted: Wed Feb 26, 2003 19:08
it works like a charm now, I mixed cs1 & 2 indeed. thx again, you're tha man 8)
Luv the program btw
 Post subject: Same problem...but
PostPosted: Fri Sep 12, 2003 8:16
I have the same problem, my screen sides are switched, but CS1 and CS2 are pinned out right.
PC LCD
14 12
16 13
I'll re-double check my wiring too!
I'm using a CFAG12864BTMIV. Everything else works great!
Any ideas? :idea:
TIA :D
Iridium
 Post subject: Re: Same problem...but
PostPosted: Sun Sep 14, 2003 19:05
Just try switching the CS pins. ;)
PostPosted: Thu Sep 18, 2003 14:46
That's exactly what I did. :D
Thanks for the great program Henri!
Iridium
