It is currently Tue Nov 17, 2026 4:48
 Post subject: USB Support!!!
PostPosted: Sun Mar 23, 2003 13:21
Hi! It would be really great if you could include a usb support in you next version! (internal PC connection!!!) :idea:
PostPosted: Sun Mar 23, 2003 15:48
Hmm, for what kind USB hardware should this support be ? Writing USB driver shouldn't be much harder than writing a regular driver if the hardware/firmware specs are known.
 Post subject: not sure but...
PostPosted: Mon Mar 24, 2003 11:04
USB would be REALLY nice as all new MoBo's have internal USB so just a 4 or 5 pin header cable and you got data AND power.
Schijf at http://liquidmp3.schijf.org/ is working on some USB, would be nice if it was the same as LCD info!!!
PostPosted: Mon Mar 24, 2003 18:03
I have thought of building Zotty's USB2LCD II when he gets it ready. And if it then does the job I don't have to spend my time on my own USB LCD anymore. ;)
So I think support could be expected sometime in future. Has anyone yet built the older USB2LCD ?
PostPosted: Mon Jul 14, 2003 19:29
Speaking of USB, does anyone know if it would be possible to wire a Noritake 800A VFD to go through an internal motherboard usb header? Could I just buy a serial to usb adapter and rewire the usb end for an internal connection? Thanks!
PostPosted: Tue Jul 15, 2003 11:28
It won't be this simple with the 800A as it isn't a serial display. With serial display serial to usb adapters should work.
I'm working on parallel adapter that should work with 800A also.
