It is currently Sun Nov 15, 2026 2:52
PostPosted: Sun Apr 27, 2003 0:42
hi all
i have a problem ... i need the commands for TRaffic in & traffic out ... and I Need the command to show the speed of the network...
please help me ...
so long cr!me
PostPosted: Mon Apr 28, 2003 23:19
I think these are still missing from LCDInfo. Unless they can be found from the NT performance counters. Have you looked into the performance counters yet ?
PostPosted: Tue Apr 29, 2003 0:09
when come thease commads for lcdinfo?
and the seconed kind? can u tell me the commands for the nt performance counters... or the kind of of using thease commands?
i hope the commands are comming soon ;)
*my english is bad i know * ^^
! ! thanks for helping ! !
so long cr!me
PostPosted: Thu May 01, 2003 15:20
I'd be happy to tell you this if I knew. But currently I can't say anything definite.
You can set the names for these yourself in the config program. Under "NT Performance Counters" tab you can add and remove counters. You can give a name to specific counter and then you can use that name in your screen ini files.
Performance counters are only available in the NT version.
PostPosted: Sat May 03, 2003 2:12
thanks ... it works perfektly ...
:D
so long
