It is currently Sat Oct 17, 2026 22:21
PostPosted: Fri Aug 29, 2003 16:26
Hi all.
I just finished to wire my LCD.
Under LCDinfo, no problem:
But, with LiquidMP3, hum, it's funny:
Can someone help me?
Does it a wire problem or LiquidMP3 config?
Thx in advance.
PostPosted: Fri Aug 29, 2003 16:30
hum...
sorry, but i just found it's a soft problem with LiquidMP3, inversion with CS1 and CS2. Not logical but it work.
Bye!
PostPosted: Mon Sep 01, 2003 8:47
Hello I'm having the same problem, but mine LCD works fine with LiQuiD-MP3, but is inverted with LCDInfo, how can i solve this problem?
PostPosted: Mon Sep 08, 2003 14:42
Well, these currently available LCDInfo versions don't support defining your wiring so your only option is to switch the CS pins to make it work right with LCDInfo.
PostPosted: Fri Sep 26, 2003 11:28
Hi Drogon,
I Have got the same LCD than you :D but unfortunately I have no cable to plug with it :cry: . Could you give me a picture of the connection you did to make it work.
Thanks a lot
PostPosted: Sun Sep 28, 2003 16:48
Sorry for my post :( , I finally find the shematics on this forum :P
http://www.skippari.net/phpBB2/viewtopic.php?t=286 :D
How Henri wasn't to sure about his shématic, so I decide to build the one from Mail.eve. :?
I just finish it and he works well, I'm going to test the prg from Henri.
Thanks for this Henri
ZOOLS Image
