It is currently Sat Oct 17, 2026 20:03
PostPosted: Tue Sep 30, 2003 15:35
:idea: :idea: :idea:
First of all Thanks a lot Henry for your LCDinfo. :)
It's a cool prg ! Without him I could'nt use my lcd CFAG12864B-TMI-V 8)
I notice that you used in some variables, the charters "()" for example :
$mailcount(0) $
This is a problem if we want use it in the graphique ligne because the "()" are already use in this case for exemple :
Graphic0=text"("39,30,4,$localip$")"
It's a shame because I wished giving a biger font to see the e-mail counter. :roll:
In your last version of LCDinfo it's possible to change the color of the lcd display in the ini file. Could you put an html color code, that would be cool to change it to got the same color as my desktop. :P
ZOOLS
PostPosted: Tue Sep 30, 2003 18:14
$mailcount(0) $
Are you sure this isn't working in the latest 0.4 versions that are available for example here: http://www.skippari.net/phpBB2/viewtopic.php?t=268 ?
This is the same bug as here ?
http://www.skippari.net/phpBB2/viewtopic.php?t=71
I thought I had fixed it so that using several () should be no problem. But I might be wrong...
Hmm, I think I've written some code for LCDInfo that allows using any color. But it was probably some code that haven't been released yet. Not sure.
PostPosted: Thu Oct 02, 2003 12:45
Hi Henry,
Sorry to ask always the same thing that has been already talked somewhere in the forum :(
Perhaps you could put your pre version of LCDinfo to your web page to say that is in test :?:
Well I'have got some trouble to instal this one :
http://www.skippari.net/lcd/alpha/Lcdinfo0.4pre14.ace
He said that I'missed some DLL, witch I put one after one but at the end I've got a fatal error.
You said (Didn't have support for KS0108 if I remember correctly.) Do you mean help file or hardware support, because my screen is a CFAG12864B-TMI-V and I think he work on KS0108. :?
Anyway I try this one too .
http://www.skippari.net/lcd/alpha/Lcdinfo_0.4pre11.ace
He work but I'have got bad graphic on my LCD screen and errors :(
Well I'm happy with the V0.3.2 even there is few bugs in positionning graphics and I'm waiting impatiently your next finial version 8)
Could you list somewere your code of color
Thanks a lot for your hard work on this project.
Zools
PostPosted: Sat Oct 04, 2003 11:24
I could do that but the reason I haven't been advertising them much is that I haven't worked on them for the last 9 months and I know there are problems. Also I have no intentions to fix the problems as I'm working on a completely new LCDInfo.
There wasn't code written for KS0108 so there's no way to get it work with KS0108.
Sorry to hear about your problems but I don't think there's much I can do for them now.
The colors I mentioned were using just the tree RGB values so you were able to set them as you like but they aren't used in any program available now.
Users browsing this forum: No registered users and 137 guests
