It is currently Fri Oct 16, 2026 17:11
PostPosted: Wed Oct 08, 2003 11:53
Hello,
having a winstar wg240128b i'm wondering how to interface to the lpt in order to work with lcdinfo
any hints or urls?
thanks,
frog
PostPosted: Wed Oct 08, 2003 15:28
Here a link to the datasheet for your LCD (you'll need it to identify the pins):
http://www.urdamerica.com/WG240128B.htm
and here's a link to the wiring schematic that I used for my 240x128 LCD (can't remember where its originally from):
http://www.reloded.com/misc/DV_t6963c.gif
Your LCD has built in negative voltage, so as long as you substitute your LCD pin order for the one in the diagram, you shouldn't have any problems getting it to work.
I'm a bit dubious about the reset switch in the diagram. You could just wire 5v into the reset pin to or if you want a reset button, use a push-to-break switch instead of the components used in the diagram. (I say this because I found that if you are powering via, say, a computers PSU's 5v line, then it could cause the computer to reset rather nastily when you press the LCD reset button. Happened to me anyway, but I'm no electrical expert. I think if you want a reset button as in the diagram, then you need to provide the 5v from a source other than the one powering the LCD. Maybe... :D)
PostPosted: Wed Oct 08, 2003 15:31
Oops, forgot to login before!
PDF version of above datasheet:
http://www.mostron.com/pdfs/pdfgraphic/WG240128B.PDF
 Post subject: thanks
PostPosted: Wed Oct 08, 2003 17:00
