It is currently Tue Apr 16, 2024 21:59
 Post subject: Shutdown bug (MBM)
PostPosted: Sun Oct 27, 2002 23:45
There have been some problems with LCDInfo and shutting down windows. This is most likely because MBM is closed first and then LCDInfo can't read the shared memory anymore resulting in an error.
This seems to have been fixed when using the latest (5.2.0.0 + 02 Oct update) version of MBM.
PostPosted: Tue Jan 14, 2003 13:02
i don´t use MBM, but the problem exists with me also!
if LCDinfo is running, windows don´t shutting down.
i must first close LCDinfo and then shutting down windows.
where does the problem lie? :?:
GROUPGLOBAL
PostPosted: Tue Jan 14, 2003 18:21
MBM was the reason for the old bug that wasn't problem in 0.3.1 anymore. In 0.3.2 there is some new bug causing this.
Discussion about this new bug:
http://www.skippari.net/phpBB2/viewtopic.php?t=89
